In Mother Russia...performance charts are for sissies!
And they have an OUTSTANDING safety record...Well...that wasn't sketchy as all hell. UTair is a scheduled pax airline over there.
in case you need the tag.Well...that wasn't sketchy as all hell. UTair is a scheduled pax airline over there.
No. You didn't.I like it!
Yeah.......I think "wet dirt" isn't the same as 8-12 inches of standing water. Does the POH reference standing water any where?Out of curiously, I briefly looked though An24 POH, it appears that it’s approved for dirt airstrips; POH contains performance data for dirt surfaces and even has recommendation how to perform takeoff from wet dirt surface, recommendations when to abort takeoff, etc. I would cautiously suggest that the above video is within POH limitations for that airplane.
And we wonder why there are so many plane crashes over there. Three things came to mind:
1) He barely made it off the runway because of that crap
2) Can anyone say engine failure due to mud ingestion
3) The tail had tons on mud on it...not very kosher for an aerodynamic section of the plane.
Not to mention the damage to the propellers. Water erosion is a concern for seaplanes, I'm sure dirt/ mud isn't any easier on the leading edges of those blades.
Its ok, the ice vanes are open.I'm sure it's MUCH worse than just water. Essentially, you're seriously sandblasting the blades, and you know that some of the grit is going through the engines. Last I checked abrasive debris going through a gas turbine didn't exactly help reliability.
