Found the answer at
http://www.talgarthgc.co.uk/radio.php.
It's a UK thing.
ACKNOWLEDGE Let me know you have received and understood this message.
AFFIRM Yes
APPROVED Permission for proposed action granted
BREAK Indicates the separation between messages
CANCEL Annul the previously transmitted message
CHANGING TO I intend to call…(unit) on…(frequency)
CHECK Examine the system or procedure (no answer normally expected)
CLEARED Authorised to proceed under the conditions specified.
CLIMB Climb and maintain
CONFIRM Have I correctly received the following…? Or Did you correctly receive this message?
CONTACT Establish radio contact with…(your details have been passed)
CORRECT This is correct.
CORRECTION An error has been made in this transmission (or message indicated) The correct version is…
DESCEND Descend and maintain.
DISREGARD Consider that transmission as not sent
FREECALL Call…(unit) (your details have not been passed—mainly used by military ATC)
HOW DO YOU READ What is the readability of my transmission
I SAY AGAIN I repeat for clarity or emphasis
MONITOR Listen out on (frequency)
NEGATIVE No; or permission not granted; or that is not correct
OVER* My transmission is ended and I expect a response from you
OUT* This exchange of transmissions is ended and no response is expected.
PASS YOUR MESSAGE Proceed with your message
READ BACK Repeat all, or the specified part, of this message back to me exactly as received.
REPORT Pass requested information
REQUEST I should like to know…or I wish to obtain
ROGER I have received all your last transmission.—under no circumstances should this be used in reply to a question requiring a direct answer---(AFFIRM or NEGATIVE)
SAY AGAIN Repeat all or the following part of your last transmission
SPEAK SLOWER Reduce your rate of speech
STANDBY Wait and I will call you
VERIFY Check and confirm
WILCO I understand your last message and will comply with it
WORDS TWICE Please send every word twice or I am sending every word twice.(because communication is difficult)
