Not exactly looking for free dual, but if someone wants to put me through a c172 systems gauntlet. Feel free. I'm stuck in jury duty allll day.![]()
Is it a new 172 or pre-84?
Draw the fuel system
I'll do it at home....but, 2 wing tanks which hold 43 gallons total, 40 useable. Two tanks are connected by a common hose. The fuel caps are located on top. The fuel sumps are located on the inboard under side of the wings. the fuel is gravity fed from the tanks to the carb. down to the mixture control and throttle. Beside the carb is the strainer i believe. Down from the throttle is the fuel selector. I should really look this one up....pretty rusty.
Look at a cockpit poster and point at each instrument required for flight.
Tachometer
Oil Pressure Gauge
Manifold Pressure Gauge if equipped
Altimeter
Turn Coordinator
Oil Temperature Gauge
Fuel Gauge
Flotation Device (for commercial flights beyond power off gliding distance over water)
Landing Gear Indicating Lights
Airspeed Indicator
Magnetic Compass
ELT
Seat belts
How would you know if your static system were iced up?
Airspeed Indicator turns into an altimeter. If you climb airspeed shows lower than normal cruise vice versa for a lower alt. cruise speed.
What type of flaps are on the 172, what are the operating limitations associated with flaps.
Plain flaps. Vso 39 KIAS. Vfe 85 KIAS. Slips not to be performed with flaps extended. Flaps are 10,20,30 & 40 degrees.
The venting is on the underside of the left wing, close to the pitot tube which allows air to enter in order to avoid the vacuum effect that would occur once fuel is sucked out of the tank. The vent allows air to fill in that space. If the vent were plugged fuel starvation could occur.
Nope, it wasn't a trick question. While the examiner could put up a scenario about minimum equipment in specific airspace, my question is assuming basic day vfr in uncontrolled airspace. One of your TOMATOFLAMES acronym items is wrong. Not trying to be a punk, but review 91.205.Sure about that list?
Well, 2 way radio communications for the specific flight and a transponder. Is that what you're getting at?
Congrats again on your CFI
Oh you're right. I just remember your earlier post saying that the DPE liked how you were explaining things and that you'd make a great CFI. I jumped to conclusions. So what are you using for your complex?
I think the idea of cruising with it selected on one side is so you can gauge what kind of gph you're burning. Never done it though.
POH says they are slotted flaps... many would argue they are semi-fowler, but go with what the POH says.
Yep, you're right.
Are you sure you can't do slips with flaps extended?
I have only ever flown in flight it it out of both when I was getting a much faster fuel burn out of one tank then the other causing me to hold a tad of aileron to keep it flying straight, due to the weight difference.
C-172 has Slotted flaps. I use to be in the group of the simi-fowler, but I had my commercial CFI say next time you pre-filght look at where the flaps are before you put them down and then after you put them down. On the 172 they dont add anymore to the planform of the wing which is what a fowler flap does.
ditto to what Nick said about the flaps
I addition to what rframe has already given you, I would suggest to go over.
Oil System
How the Engine works (ie the 4 cycles)
How the alternator control unit works
How the Main gear works
Pitot static system
All the performance data
and just to be safe the privileges and limitation of a commercial pilot
Straight from the POH. I've heard the debate though.
If you're working on your CFI, this is exactly the kind of "argument" you will have to explain and deal with in your job. Have your instructor "explain and deal with it" with you. There is much to be learned about "applied" aerodynamics, and also the differences in same make/model, and the damage that 'rote' habits and verbal information can do.Power off 180's usually work out OK but I naturally want to keep things tight and then dump and drop, so I have to consciously extend my pattern. More than once my instructor has pointed at the "Avoid Slips with Flaps" placard as a not-so-subtle critique of my approach.
That usually makes me want to get into a semantic argument about the meaning of "avoid"... but I dont think that'd go over so well :laff:
