Ok thanks well that is what I was wondering....If I go in with an instrument rating then I will need 10 hours dual instruction. I have seen schools that advertise 10 hour commercial ratings. Is it possible or rather probable to do the two dual x countries (at least 4 hours there) and learn all of the maneuvers in this 10 hours?
Thanks bhh1128 I wouldn't think the dual pre PPL x countries would count. But I was wondering on the solos.
I'm not sure I understand your question, but let me take a crack at it.
An instrument rating requires 40 hrs of instrument time, of which 20 hrs must be dual. (Just like a PPL requires 20 hrs of dual, most people need more to get all the training done so you should expect the same with an instrument rating.) During that time you'll do your instrument cross country flights and satisfy all the other requirements as a by product of working through your instrument syllabus.
Break, break.
The commercial rating requires 10 hrs of instruction in a
complex airplane. If you satisfied that requirement while doing your instrument training, then you are "done" with it. (I say "done" with it, because there will be complex training you will have to do to prep for the commercial check ride, since at least a portion of it must be done in a complex airplane.) I chose to satisfy this requirement by getting a private MEL rating, then spending a couple hrs with my CFI in an Arrow flying the traffic pattern in prep for my CPL. (I had a bunch of PA-28 time, so the transition wasn't too difficult for me. I went this route because I owned a plane at the time and used it for my CPL check ride, except for the complex work.)
The cross country flights that are part of the commercial requirements are different from the instrument cross country. The regs only say "VFR conditions" but the FAA has historically interpreted that to mean flown under visual flight rules (i.e., you can't fly it and log simulated time). When I got ready for my CPL, I had to do this pair of 2 hr X/C flights with a CFI even though I had over 400 X/C hrs in my logbook, since none of them satisified the requirements.
As for solo time, I've also seen intrepretation from the FAA that this time is post private, so you will need 10 hrs of solo flight working on the areas of commercial training outlined in 61.127. (The FAA's argument is something along the lines of: How can you be working on commercial maneuvers while you were a student pilot?) It might be written in the DPE handbook, but I'm not sure. I think John Lynch's FAQs had a statement in there, but they aren't valid anymore. Call your FBO or DPE and ask them. Their opinion is the only one that counts anyhow.
I personally think a quote for a 10 hr commercial rating is about as realistic as a 40 hr quote for a private rating. Read the regs:
Assuming you already have 10 hrs of instrument training by getting your IR, then:
(3)(ii) 10 hrs of complex training
(iii) 2 hrs of day cross-country training
(iv) 2 hrs of night cross-country training
(v) 3 hrs of prep w/in 60 days of the check ride
(4) 10 hrs of solo
You could combine 3(ii) + (iii) + (iv) + (v), but you are going to need 10 hrs of instruction at a minimum if you don't have any previous complex training. I don't think the average pilot can go start to finish in commercial training in 10 hrs solo and 10 hrs dual. There are people who can, just like some people do their PPL in 40 hrs, but they are not the norm and you shouldn't budget your training for that.
My $.02.
