desertdog71
Girthy Member
Anybody have a good description of this? I read a little on this subject but I must admit I did not comprehend at all.
As you go up to higher altitudes, your airplane stalls at a relatively constant IAS, but the higher you go, the higher the TAS you have to maintain to stay above stalling speed. This defines how slow you can go.Anybody have a good description of this? I read a little on this subject but I must admit I did not comprehend at all.![]()
For civil aircraft, they should never actually cross, no aircraft would be certified to an altitude where they get that close together. Although I think I read somewhere that some of the early lears had something like a 40 kt window to operate in at their max ceiling.![]()
So it is similar to where Vx and Vy converge at higher altitudes and where they cross is the Absolute Ceiling?
I need to dig that up and read it again. I can't remember where I was reading it though. Its among my 20 or so books I am sure.
The best example is the U2, since it has a straight wing, and is not really optimized for high mach flight. That and the fact that it can fly at something like 70,000', means that there is only a few knots between stall and high speed buffet.
Your best bet is to get a book, like Flying Jets by Pendleton, that will explain everything and have a diagram. I searched and could not find a diagram on yahoo or google.
If it helps any, you could pick a stall speed for your imaginary airplane, say 100 KIAS, then use your e6b to find the TAS at various altitudes and plot them on a graph. Then draw in the speed of sound (661 KTAS at sea level, decreasing to 573 KTAS in the stratosphere). Then draw in the service ceiling of your imaginary airplane at 45,000 MSL. The narrow area at the top of your graph is coffin corner.
Isn't that where you punt directly into the corner and try and get he ball to go out of bounds within the 5 yard line and without letting the ball go into the endzone. Don't want that touchback but at the same time you want to give the other team the worst field position as possible![]()
In helicopters, it's high altitude (over 30 feet) and low airspeed (under 30 kts)
Yep...and yep.
Oh, I haven't had my hands around a cyclic & collective in over 10 years. I'm 'schoolin' it in Cessners...Cool... what are you flying?
