Citation Sovereign pay
cmill
Cold Ass Honky
IIRC, NBAA has that weight class (30,000) at 50k median for SIC base pay in the south east.
EDIT: I think Conklin DeDecker has pay quite a bit higher (around 70-80) if you think you can get away with using them.
AVIATOR83
I applied for a CE680 job last year and they offered between 67k to 89k for FO spot in the Midwest. I fly a CE750 which is pretty much the same size and will say you should be looking well within that range as base salary. Obviously having the type already increases your leverage for negotiating and I am speaking more in terms of pt. 91.
Jimmy_Norton
Opie killer
Thank you much. Do you have a ballpark on how much a PIC type costs in the 680?
AVIATOR83
No idea. However, when I worked at FSI, a ce750 type was around 37k and a ce560xl was around 25k I believe. The ce680 is going to be in that range, probably closer to the high side. I could find out exactly what it is if you're that interested.
Jimmy_Norton
Opie killer
It's not a big deal, I was just curious. Tnx
