I'm having a hard time understanding this part. A book I have says the AoA is increased on the tail when the nose pitches down, causing it to nose up with a forward CG? Wouldn't this be the same for an aft CG but a lesser extent since it has less down force?
Does the nose pitch up with an aft CG when there is increased lift because the tail has less down force, and pitches down with fwd CG because it has a greater down force?
First understand that no horizontal stabilizer (H.S.) is needed for an aircraft to be stable. All that is required is that the CG be ahead of the A.C. However, the aircraft cannot be trimmed without a horizontal stabilizer (H.S) and so will not be flyable. The reason is that lift doesn't usually act at the CG and so will be generating a pitching moment around that point either nose down (negative) or nose up (positive). You need an H.S. to counteract that.
Stability is all about how the aircraft reacts to
changes in lift. Picture an airfoil with the CG ahead of the leading edge; imagine an increase in AOA due to a gust. You can see that the airfoil's lift would try to pitch it down, around the CG, lowering the AOA. This is stability.
So the airplane is in a delicate balance. The H.S. keeps the aircraft from nosing over due to the fact the lift is acting behind the CG. However, when a gust strikes, lift increases and tries to pitch the nose down again. Also, the down force on the tail is reduced and it helps the inherent stability of the main wing.
Now, as you move the CG back, the wing's stability decreases; once you move it to coincide with the A.C., the wing makes no contribution to the stability of the aircraft. However, the horizontal tail still does. In fact, you can move the CG a bit behind the A.C, due to the extra stability the H.S. provides, but the instability of the main wing is now
fighting the H.S.
At some point, as you move the CG back, the stability of the aircraft becomes neutral, and that point is called the "neutral point". If you move the CG back any further, the airplane is unstable. (But still flyable.)
So the H.S. contributes to the stability of the aircraft and can greatly increase the safe CG positions, particularly when you have a real long moment arm, such as on transport category aircraft.
