CFIT due to a lightbulb....
Swen
IPA Consumer
I'm working on a paper dealing with CFIT and have to reference 3 NTSB accidents. I want to use the accident in which the plane crashed because the crew was occupied with the lightbulb that burnt out on something. The problem is thats all I remember about it and cant get any search results. So if anyone can tip me off as to the airline, date or anything else I'd appreciate it.
It was EAL 401, December 29th, 1972.
Start with that in Google and you should get something. Mostly about ghosts and Ernest Borgnine, but it was a long time ago.
NTSB Identification: DCA73AZ005
14 CFR Part 121 Scheduled operation of EASTERN AIR LINES INC
Event occurred Friday, December 29, 1972 in MIAMI, FL
Aircraft: LOCKHEED 1011, registration: N310EA
---------------------------------------------------------------------------------------------------------------------------- FILE DATE LOCATION AIRCRAFT DATA INJURIES FLIGHT PILOT DATA F S M/N PURPOSE----------------------------------------------------------------------------------------------------------------------------1-0016 72/12/29 NR.MIAMI,FLA LOCKHEED 1011 CR- 5 10 0 SCHED DOM PASSG SRV AIRLINE TRANSPORT, AGE TIME - 2342 N310EA PX- 94 50 17 55, 29700 TOTAL HOURS, DAMAGE-DESTROYED OT- 0 0 0 280 IN TYPE, INSTRUMENT RATED. OPERATOR - EASTERN AIR LINES,INC. DEPARTURE POINT INTENDED DESTINATION JAMAICA,NY MIAMI,FLA TYPE OF ACCIDENT PHASE OF OPERATION COLLISION WITH GROUND/WATER: UNCONTROLLED IN FLIGHT: UNCONTROLLED DESCENT PROBABLE CAUSE(S) PILOT IN COMMAND - INADEQUATE SUPERVISION OF FLIGHT PILOT IN COMMAND - DIVERTED ATTENTION FROM OPERATION OF AIRCRAFT MISCELLANEOUS ACTS,CONDITIONS - INSTRUMENTS-MISREAD OR FAILED TO READ FACTOR(S) MISCELLANEOUS ACTS,CONDITIONS - CREW COORDINATION-POOR AIRFRAME - LANDING GEAR: LANDING GEAR WARNING AND INDICATING COMPONENTS FIRE AFTER IMPACT REMARKS- CREW DIDNT MONITOR INST & DETECT UNEXPECTED DESCENT.PREOCCUPIED BY NOSE GR PSN IND SYS MALFUNCTION
Another similar one was UAL 173 at Portland, December 28, 1978. Ran out of gas and crashed in the suburbs of Portland while worrying about a landing gear indication. Most passengers survived, some even crawled out of the wreckage and walked home. But this accident was the impetus for today's CRM programs.
NTSB Identification: DCA79AA005
14 CFR Part 121 Scheduled operation of UNITED AIR LINES INC
Event occurred Thursday, December 28, 1978 in PORTLAND, OR
Aircraft: DOUGLAS DC-8, registration: N8082U
---------------------------------------------------------------------------------------------------------------------------- FILE DATE LOCATION AIRCRAFT DATA INJURIES FLIGHT PILOT DATA F S M/N PURPOSE----------------------------------------------------------------------------------------------------------------------------1-0017 78/12/28 PORTLAND,OR DOUGLAS DC-8 CR- 2 2 4 SCHED DOM PASSG SRV AIRLINE TRANSPORT, AGE TIME - 1815 N8082U PX- 8 21152 52, 27638 TOTAL HOURS, DAMAGE-DESTROYED OT- 0 0 0 5517 IN TYPE, INSTRUMENT RATED. OPERATOR - UNITED AIR LINES,INC. DEPARTURE POINT INTENDED DESTINATION LAST ENROUTE STOP NEW YORK,NY PORTLAND,OR DENVER,CO TYPE OF ACCIDENT PHASE OF OPERATION ENGINE FAILURE OR MALFUNCTION IN FLIGHT: HOLDING COLLIDED WITH: TREES LANDING: ROLL PROBABLE CAUSE(S) PILOT IN COMMAND - MISMANAGEMENT OF FUEL PILOT IN COMMAND - DIVERTED ATTENTION FROM OPERATION OF AIRCRAFT MISCELLANEOUS ACTS,CONDITIONS - INATTENTIVE TO FUEL SUPPLY MISCELLANEOUS ACTS,CONDITIONS - FUEL EXHAUSTION FACTOR(S) AIRFRAME - LANDING GEAR: NORMAL RETRACTION/EXTENSION ASSEMBLY AIRFRAME - LANDING GEAR: LANDING GEAR WARNING AND INDICATING COMPONENTS COPILOT - MISMANAGEMENT OF FUEL PERSONNEL - FLIGHT ENGINEER: OTHER COMPLETE POWER LOSS - COMPLETE ENGINE FAILURE/FLAMEOUT-4 ENGINES EMERGENCY CIRCUMSTANCES - FORCED LANDING OFF AIRPORT ON LAND REMARKS- OTR CRW MEMBERS FAILED TO CONVEY CONCERN ABOUT FUEL EXH TO PIC UNTIL ACDNT WAS INEVITABLE.
Printable brief - Please change to print landscape.
Swen...do we get a partial grade as well.
did you search here:
NTSB Website
Thsi site is a gold mine. I read it on a regular basis just to see what kind of mistakes are being made and what there is that can be learned from them.
NTSB Website
I get the accident narratives from there, but never made use of any other feature. But I'll check it all out this time.
the ntsb.gov site is OK, but if you're doing research here's a better one: nasdac.faa.gov
It gives you access to the entire NTSB database like ntsb.gov, but it has more robust search options so you can narrow down what you're looking for. You can also search ASRS reports, the FAA incident database, and other stuff from this site.
