Why would you want to do the Double-I as your initial?
It;s been pointed out in probably a dozen threads here that you aren't allowed to teach in an airplane with only the Double-I.
Ground school? Sure
Simulator or FTD? Sure
Airplane? Absolutely not; not without the CFI-A
Cuz I'd follow up with the CFI-A. There's supposed to be a lot less they can ask you about in the oral for doing a CFII as initial. There's a reason the pilot mills do it this way.
I agree, if they told that's the way to do it, then they should know why and how to prep for itAsk whoever told you that for some pointers on what portions of the PTS won't be covered using this method.
Ground school? Sure
Simulator or FTD? Nope
I intend to do the same thing. For one, just like any other Instrument ride, you either meet the standards or you don't. There's less opportunity for examiner discretion to come into play.
I apologize for not reading all posts, so if what I say has been already, well, please excuse my ignorance! Just as an instrument rating is an additional rating added to an existing pilot certificate, you can't get one without already being certificated. CFII is the same, you cannot get the "instrument airplane" added to a cfi that you don't already have.
That is not correct. There are many airmen who hold a CFI-I but do not hold a CFI-A. Their number will likely diminish in the future due to the FAA's recent interpretation of what a CFI-I without a CFI-A is authorized to do, but it is still possible to obtain a CFI-I without holding a CFI-A.
I suppose that is true, depending on where you are. I know the rules are rules, but each FSDO operates much like an independantly owned and operated franchise of the FAA, my understanding here in the WP-07 is that is not to be done. One could do the MEI as initial but not the IR. I can check my FSDO to find out...
The first is to ask for a legal interpretation from the Chief Counsel's office.
