andreasmkr
I have a question for you guys that know the g-1000 system pretty well..
In the checklist for the G-1000 C-172SP it tells you to turn off the stby battery if you have an overheating announciator for the PFD/MFD..
In my eyes it makes no sense in just turning the STBY batt off. You should turn off your PFD&MFD for them to not overheat completely?
Scenario:
Say you are en-rounte to your destination (IMC), you get hit my lightning but there is no announciator indication that any of your equipment is malfunctioning.
After a 10 min of flight you get an overheating warning on the MFD & PFD. (PFD/MFD FAN HAS FAILED)
Nrst airport is 25 nm from your position and you request a GPS approach into that airport.
En-route to your alternate... do you leave your PFD & MFD like the checklist says or do you turn off your avionics I & II, MSTR AND Stby battery?
My answer:
Notify ATC that your system is overheating and that you are tuning all electronic equipment off for a period of time en-route to your IAF. You note your ground track and compare it to your mag compass. After notifying ATC and turning the MST off and avionics of, you follow the mag compass for a certain amount of time and then contact ATC when you turn the system up again and cross-reference your track with the track to your IAF.
Then you are basically saving your PFD&MFD for the approach and not wasting it for your en-route flight..?
What do you guys think?
Scenario:
My answer:
