I never used the parking brake for my initial training. Also, ATP SOP was to not use it. The first time I started using it regularly was when I got the the left seat of a jet.
I was reading their Seminole manual and I noticed that that don't like using the parking brake. Any reason behind that?
Another thing I always wondered was when a plane is tied down the brake is never set. Is that because it can seize up?
Yeah I know right! Too bad we're underage though. I did get it unstuck though. I just had to press the pedals extra hard. Thanks though
Wow I say though a lot. I guess that's what you get for trying to type a message on a golf cart.
I know now not to set the parking brake on piston airplanes. I've never really had a problem before this. Weird.
If you leave it set in the morning, as the fluid heats up it can build up pressure and blow seals. Likely?
152 parking break is horrible, they have good regular breaking anyway.
I would always use the parking break on the Tomahawk though, not the best breaks and wasn't the biggest pain to deal with.
It's brake, not break![]()
*pun intended* :cwm27:
