MNFlyboy
Question towards your take on "Captain will ensure properly secured cargo". That's an abbreviated version of what is in the SOP, and referencing the POH, there are several cargo restraining systems. Our aircraft have the throw over net, open weave style, not the solid webbed ones. The question at hand is, is it legal for you to "bulk out" the aircraft and not use a restraint system (i.e. strapping it down)? Common sense would suggest that the restraints are used to secure and prevent load shift in flight, take off, and landing. This I get. But if zones 1-5 are full above the 75% capacity line, to the roof, and either zone 6 is occupied or the zone 6 barrier is securely in place, does this meet the requirements? Some captains will use this logic and bulk out the cargo zones and shut the door, others will refuse the last bit of freight to use the restraints. Thoughts?
