Timbuff10
I had always just used the TC before but I learned a little trick today that seems to make sense.
Take the first two digits of your airspeed (or just the first digit if you are under 100kts) and add 5 to it. That is your bank angle to get a std rate turn.
120 kts, add 12+5=17 degrees of bank gives you a standard rate turn.
90 kts, add 9+5=14 degrees of bank gives you a standard rate turn.
I was told it works in any sort of airplane but I am not so sure if 30 degrees of bank will give you a standard rate turn in a airliner doing 250 kts.
Anyone ever heard of this?
