Very incredable.
IIRC the problem with the C-130 COD program was that it couldn't carry as much weight for that size aircraft. Those test flights had no cargo, and were a really light weight. I belive that for carrier ops, the C-2 could actually carry more cargo than the C-130.
More info from the website Copaman listed:
All told, the flight tests included 29 touch-and-go landings, 21 unarrested full-stop landings, and 21 unassisted takeoffs at gross weights ranging from 85,000 lb (38,555 kg) to 121,000 lb (54,885 kg). At the lower weight, the aircraft managed to come to a complete stop in only 267 ft (81 m), which is little more than double the plane's wingspan. Even at maximum weight, the C-130 required only 745 ft (227 m) for takeoff and 460 ft (140 m) for landing. Landings were made shorter by reversing the propellers while the aircraft was still a few feet above the flight deck.
Based on these tests, it was determined that the C-130 could carry 25,000 lb (11,340 kg) of cargo and personnel to a carrier at a range of 2,500 miles (4,020 km). However, the risks of operating such a large aircraft in the hectic day-to-day carrier environment were considered too great, and the idea of using the C-130 as a COD aircraft was abandoned.
The C-130 has never been operated from a carrier since, and the much smaller C-2A Greyhound was later selected to fulfill the COD role.
I believe the C-2A can haul around 10,000 pounds.
