C-055 2 NAV Rule. Lower Ceiling or Lower Vis?
TXAce
Active Member
Hypothetical question I think I already know the answer to but still curious. If I have a list of options, let’s say my choices of mins are
ILS 16L. 200-1/2
GPS 34C - 400-1
NDB RWY 16R - 500 3/4
Which would we better to use for the 2nd Navaid? Lower ceiling or lower vis
I think it’s lower vis but I want to make sure
Depends on what you need to suit the forecast. If visibility is forecast at 1 1/4 with a 900 foot ceiling, you take the vis. If forecast is 2 miles vis with a 600 ft ceiling, you take the ceiling.
What are forecast winds for alternate at ETA? What kind of approach are you using at your destination? Both are factors.
ILS 16L. 200-1/2
GPS 34C - 400-1
Depending on what you use, either way you’re screwed. If this was my only option, I’d just use the 1 navaid rule on the ILS with higher vis and call it a day. You can save the lower vis as a backup or… just go with a different alternate.
ILS 16L. 200-1/2
GPS 34C - 400-1
What are the forecast winds?
For 2 runways it is the higher of both vis and cig
i think that’s understood. in the example given by OP, the combination of approaches using the GPS approach gives you a better ceiling while the NDB approach gives you slightly better vis
There is an 80 degree difference…and the 2 navaid rule says “suitable runway”
