Anybody's guess. If you have access to the maintenance manual, AND the hobbs in there is still the factory OEM install, you MIGHT be able to figure it out. I say MIGHT because in the case of our Navajo, it just shows a pressure switch in the schematic. No mention of what pressure it is (oil? if so, which motor?). Unfortunately, many older aircraft have had the Hobbs circuit modified or never had a hobbs in the first place, so the install is aftermarket and often the only way to figure out what powers it is to trace wires. Different variations I've seen: Battery master, Avionics bus, oil pressure (straight from the battery), oil pressure (off the main bus), pitot pressure, gear up and in the wells...
