Yuma Approach cleared me to 1,200 on a night IFR flight plan about I do know that the emplyoyees of that base are a bunch of young reservists who are obviousy not capable of the responsibilty. NTSB reports confirm that at least 2 F-18s have collided with terrain at night while on with Yuma Approach. Makes you wonder how many more pilots will have to die before someone puts the hammer down.
Whoa there, hoss, those are pretty scathing and broad allegations. I've worked with NYL RATCF many a time, both in civilian flying and military. Their GCA folks are some of the best I've seen, and I received a PAR down to 100' one night after NYL became my second divert for WX and I was on min fuel vectors on one of 6 days a year that place gets hard WX. I also know that the civilian TPA there is 1,200, and all aircraft are to be established at 1,200 within 5 nm from the field so as not to conflict with the 1,700 TPA for the mil jets; and they generally issue pilots-discretion from about 10 miles out, so you weren't being vectored for an approach, you must've been given a descent for a visual approach. I don't know your case personally, and ATC does make mistakes, but the controllers there are far from "untrained reservists".
And night below MEA or in IMC is no problem, we did that every night in Afghanistan, it's just up to the pilot to know where he's going and what's under him, using ATC as an assistance and not a crutch. It's can be done, it's a little more work, but if ever the mission justifies the risk, with a little planning and a lot of SA it isn't impossible.
Curiously, why would the NTSB have reports on military F/A-18 crashes in relation to an military ATC facility? That's outside their scope of investigation.
