trying to wrap my brain around this… apparently it's a common interview question……….
It decreases. A high ISA really slows things down.
Colder air produces more thrust, all else being equal. The higher you go, and the hotter it is, the worse the engine performance...hence high and hot takeoffs being a special item always taught.if OAT **DECREASES** is the question… I said "thrust decreases" but now we have a conflicting answer here..
You mean as OAT increases, no? Denser air should mean more thrust...
Every jet aircraft I've flown measures air temperature in terms of ISA.
ISA is -35 deg C above FL310
Sure, not a jet guy here...but at a given altitude, if the temperature goes down, the air is more dense - thus you're getting more mass moved through the engine, thus more thrust I would think. All other things being equal, cold air should be more "giddyup."
I guess I'm over thinking it - I was thinking about the thrust increasing/decreasing as you went from the ground up to FL350 etc.. but they're maybe talking about thrust available for takeoff on a day that's hotter or colder…
thanks for the replies!
Right but your first post in this thread was backwards on the first sentence. That's where the confusion came from. Colder air, everything else being equal, produces more thrust. If you're at 310 at ISA, and it gets warmer, you lose thrust. if it gets colder than ISA then you'll produce more thrust.Every jet aircraft I've flown measures air temperature in terms of ISA.
