AROW Documents
Pilot Hopeful
Many of us use the ARROW (AROW) acronym to recall the required documents that must be on board the aircraft before flight. Yesterday, I began a search to find the regulations that specifically require these documents.
I readily found the Airworthiness, Registration, and Operating limitation document requirements in 91.203, 91.203, and 91.9 respectively. However, I am still seeking the regulation requiring Weight and Balance information to be aboard the aircraft.
Does anyone have the address for the corresponding Weight and Balance FAR requirement?
Personal FAQ:
You won't find a specific regulation that says that the weight and balance numbers must be on board. I've seen the issue bandied about some on various forums. I'll offer the collected wisdom (?) of those discussions.
There are two primary sources of the requirement.
1. If you remember your 91.213 airworthiness analysis, ultimately, whether a piece of equipment is required or not is based on the airplane's Type Certificate Data Sheet . In some cases, not all, the TCDS contains language like:
Current weight and balance report including list of equipment included in certificated weight empty, and loading instructions when necessary, must be in each aircraft at the time of original certification and at all time thereafter...
So, the presence of the weight and balance data is as much an airworthiness requirement as operating fuel gauges.
But not all aircraft have this requirement on the TCDS.
2. 91.9(b) contains the requirement for the presence of systems information on board. (The reference to 21.5 is a reference to the requirement for an approved manual (AFM) after 1979)
23.1581 - 23.1589 talk about what the contents of an approved AFM manual must contain. 23.1589 says:
Loading information.
The following loading information must be furnished:
(a) The weight and location of each item of equipment that can be easily removed, relocated, or replaced and that is installed when the airplane was weighed under the requirement of § 23.25.
(b) Appropriate loading instructions for each possible loading condition between the maximum and minimum weights established under § 23.25, to facilitate the center of gravity remaining within the limits established under § 23.23.
Read them together and you get, an airplane must have its manual on board and it's manual must contain weight and balance data.
I think that there are some airplanes that still slip through the cracks but, like a lot of shorthand expressions for learning things, AROW covers the general rule. There are always exceptions.
Alright, I'm not sure, but here's what I found.
FAR § 23.1583 Operating Limitations.
The Airplane Flight Manual must contain operating limitations determined under this part 23, including the following—
(c) Weight. The airplane flight manual must include—
(1) The maximum weight; and
(2) The maximum landing weight, if the design landing weight selected by the applicant is less than the maximum weight.
(3) For normal, utility, and acrobatic category reciprocating engine-powered airplanes of more than 6,000 pounds maximum weight and for turbine engine-powered airplanes in the normal, utility, and acrobatic category, performance operating limitations...
So I think, because you're required to have the POH for the plane, the POH isn't a POH unless it has weight and balance info.
This might be reaching, but it seems to make sense.
Naunga
Note also that this means the W&B must be IN the AFM, not in a seperate folder/binder/book/whatever. Best to put one of those plastic pockets with holes punched for rings into your AFM and stick the W&B sheets in the pocket.
