Re: Any Aircraft owners out there can answer quest
The number one most important part though is to get a pre-purchase inspection. I put a deposit on a 1965 172 which was a beautiful looking and flying aircraft. Well i got in it for inspection and found hella problems. Major corrosion issues inside the wings, low compression (49/80) on two of the cylinders, a prop that had a fair amount of corrosion near the crank, and a crankshaft that was so corroded it would have made the core worthless for exchange. The pre-purchase cost me $200 but saved me $30,000 worth of issues that would have needed to be addressed.
The hardest part of finding 152/172s is that almost all of em for sale are worn out tired trainers. Most I have looked for either have corrosion issues, unacceptable damage history, 10,000+ on the airframe, or are gettting close to TBO on the engine. It is pretty darn hard to find a good one.
If you are gonna get one it might be worth you while to get something a little nicer that has not fufilled the trainer role. Such as a Cardinal,182, or Mooney. Most likely these havent been trainers therefore they arent as likely to have suffered the abuse most trainers encounter. Alot of renters (not all) treat an rental aircraft like a rented mule.
Insurance is not too bad if you have about 100 hours or so you can get insurance on a 172 with a hull value of $40,000 for about $1,000 with most agencies.
If you can find a good shop that is willing to let you help with owner-assisted annuals maintences cost can be low minus that parts that is.
Engine overhauls are a killer though. $12,000 for a basic FBO overhaul assuming there isnt alot that needs to be done. Your lookin at low 20's though for a factory reman or factory overhaul.
