Another Multi-Commercial Question
BrianNC
I have bolded the part of the comm. mulit-engine requirement below I have a question about.
It states that "or 10 hours of flight time performing the duties of pilot in command in a multiengine airplane with an authorized instructor (either of which may be credited towards the flight time requirement in paragraph (b)(2) of this section), on the areas of operation listed in Sec. 61.127(b)(2) of this part that includes at least--" and then states the "includes at least" is the long x-cntry and the 5 hours of night flight with 10 TO/L at controlled airport.
Concerning "performing the duties of pilot in command", can that be applied to any of the requirements under "training" which includes the day/night 2 hour x-cntrys'? In other words, can any of the time for the 2 short x-cntry's be classified as "performing the duties of pilot in command", or does that only pertain to the long x-cntry and any other time that does not come under the heading of "training"?
The reason for asking is I was wondering if I could count the night time for the 2 hour VFR night x-cntry (that comes under the heading of "training") toward the 5 hours in night VFR conditions (which comes under the "performing duties of pilot in command".
2nd question: As discussed in another thread, it does not state that the long x-cntry for comm. multi has to be VFR. So there would be no problem flying that under the hood in order to satisry the 5 hours of instrument in the twin, correct? (I already have my instrument which gives me the other 5 hours of instrument required).
Thanks!
b) For an airplane multiengine rating. Except as provided in paragraph (i) of this section, a person who applies for a commercial pilot certificate with an airplane category and multiengine class rating must log at least 250 hours of flight time as a pilot that consists of at least:
(1) 100 hours in powered aircraft, of which 50 hours must be in airplanes.
(2) 100 hours of pilot-in-command flight time, which includes at least--
(i) 50 hours in airplanes; and
(ii) 50 hours in cross-country flight of which at least 10 hours must be in airplanes.
(3) 20 hours of training on the areas of operation listed in Sec. 61.127(b)(2) of this part that includes at least--
(i) 10 hours of instrument training of which at least 5 hours must be in a multiengine airplane;
(ii) 10 hours of training in a multiengine airplane that has a retractable landing gear, flaps, and controllable pitch propellers, or is turbine-powered, or for an applicant seeking a multiengine seaplane rating, 10 hours of training in a multiengine seaplane that has flaps and a controllable pitch propeller;
(iii) One cross-country flight of at least 2 hours in a multiengine airplane in day VFR conditions, consisting of a total straight-line distance of more than 100 nautical miles from the original point of departure;
(iv) One cross-country flight of at least 2 hours in a multiengine airplane in night VFR conditions, consisting of a total straight-line distance of more than 100 nautical miles from the original point of departure; and
(v) 3 hours in a multiengine airplane in preparation for the practical test within the 60-day period preceding the date of the test.
(4) 10 hours of solo flight time in a multiengine airplane or 10 hours of flight time performing the duties of pilot in command in a multiengine airplane with an authorized instructor (either of which may be credited towards the flight time requirement in paragraph (b)(2) of this section), on the areas of operation listed in Sec. 61.127(b)(2) of this part that includes at least--
(i) One cross-country flight of not less than 300 nautical miles total distance with landings at a minimum of three points, one of which is a straight-line distance of at least 250 nautical miles from the original departure point. However, if this requirement is being met in Hawaii, the longest segment need only have a straight-line distance of at least 150 nautical miles; and
(ii) 5 hours in night VFR conditions with 10 takeoffs and 10 landings (with each landing involving a flight with a traffic pattern) at an airport with an operating control tower.
no APIC (acting pic) time is taking the place of the solo requirement in a single engine. the reason they put that there is because 1: no insurance company will insure private pilots with limited multi/total time in a twin solo. (now there are a few exceptions but we wont get into that) 2: no school will let you take there twin out solo. so the faa realizes this and allows you to log APIC instead of solo to meet that req. i would suggest having your instructor put APIC in the remarks section. it doesnt make a difference wether you log it as dual recieved or not as long as you specify that it is APIC dont log it as solo though
and dont let you instructor put down supervised solo instead of APIC since supervised solo refers to student pilots soloing with their instructor sitting on the ground or in the tower watching them.
hope this helps
Depending on the FSDO, they might want to see Dual Received. I had this problem with my APIC time from Florida in the Seneca. We had logged it as PIC, but not dual received and endorsed. So, after I spent about 45 minutes on the phone with the Ft Worth FSDO (no help) and a bit on the phone with AOPA, I was told it's really up to the individual DE, but it could still come back to bite you later. I wound up faxing a copy of the entries to my instructor (who is at XJT now) so he could endorse them for the dual received just to keep my bases covered.
hope this helps
Actually, a school here in Socal does let you take their Seminole out solo for rental if you graduate from their VFR and IFR multi courses. The training estimates given are 8 hours for the VFR course plus 6 hours of the IFR course. The Seminole rents for $182 block and $192 non-block, so its not the cheapest around of course.
Brian
The way I interpret it is that the 2 hour day/night XC has to be dual received whereas the 5 hours night VFR has to be supervised PIC or solo. So 7 hours total nighttime.
The 10 night takeoffs and landings at a controlled field are also part of that 5 night as acting PIC.
Brian
So basically the answer to my original question was "no". 5 is acting PIC and the other 2 under the night VFR is is "training". So I can't partially kill two birds with one stone.
well..... there is kind of a way. the long one must be 300nm total with one landing 250nm from the original point of departure. so if you fly somewhere over 250nm away and then 50 miles back with landing at a min of 3 points then youve met that requirement. now you already have an instructor on board since you are APIC in the multi, so you could just start working your way back logging training and one of the 2 hr- 100nm xcountries hopes that makes sense
