You don't get clicks/likes with more information.Ooh, that was scary.
I'm not going to jump on the 'newness' bandwagon. I'd love to know who was cleared to do what and why the error wasn't trapped if there was an error.
Way too little information.
I’m surprised they haven’t picked up on the TEB departures off 24 that screw the SID up and either climb through Ewr final or worse turn southbound for some reason yet
Idk the distances between the runway but if it’s greater than 2500’ then simultaneous is fine so long as they meet certain course divergence minima. Probably more rules involved than that but I’m not going to look them up right now lol. Maybe @greg1016 can shed some light there. But I don’t know how their ops work; every place I’ve worked runways have been under 2500’ so we use one for departures and one for arrivals. I’ve never worked parallels using both for same type opEven if the two airliners are going different directions in their first turn, would P50 normally release tower to launch simultaneous departures from parallel runways? Or do they stagger them at least a little bit, in order to avoid something like this from occurring at all? While these are two different complexes, at PHX supposedly, with two different tower freqs, the runways really aren’t that far apart from one another compared to some other large airports.
No worries. Gryder and Cornholio will be right in top of it with their prime time accident investigation concluded inside an hour.
Now those two clowns seemingly go up against one another in their videos from what I’ve heard.
Lemme check...
(pause)
Nope, nothing yet. I am quite titilated though. I guess he knew that Delta jet had a "textbook" engine failure before even the internal preliminary report is out.
It's magic!
The 8s in Honolulu are just over 7000 feet apart, and they will routinely launch aircraft simultaneously off of those, both with turns to the right.
Shades of when DEN ATC used to come in to recurrent ground at GreenBus. Some similar comment was made and the controller said “we love you guys, you never go around, and it makes our lives easier!” the facilitator was like “uh you can’t say that, please don’t say that.”The 8s in Honolulu are just over 7000 feet apart, and they will routinely launch aircraft simultaneously off of those, both with turns to the right.
Unrelated but way worse is the (totally legal) scenario where they will have an aircraft descending below 600 feet, in the close in left downwind for the 4s, crossing directly over or in front of an aircraft in the flare for 8L. I asked a controller once what I should do if I had to go around with another airplane directly in front of me and 500 feet above me, and his response was to not go around.
"Im done with it"
That controller sounded a bit wound up after the event - I get it. From the thousand yard view, looks like American was flying what they were cleared and could be a mix up from clearance. Good thing he checked in with his departure SID...
I agree with your assessment. Certainly sounded like it got his heartrate up, with good reason, and it wasnt his screw up and didnt have time to investigate the "why and how" and was trying to breathe again."Im done with it"
If he did more kegel exercises it wouldn’t have been a thang.I agree with your assessment. Certainly sounded like it got his heartrate up, with good reason, and it wasnt his screw up and didnt have time to investigate the "why and how" and was trying to breathe again.
