GlenA
Senior Chicken Counter
Two things happened in the past few days that I wish to share. These two things helped reinforce to me that it doesn't matter how many hours you have, you can't get complacent, because that's when things will get you. They both became non-issues because they were caught early enough, but they could have been worse if allowed to continue.
First today, as I was flying along doing my photo work, I called up approach to get flight following (always nice to have another set of eyes). I got my squawk and everything happened as per normal. A few minutes later, another plane calls for flight following, also gets a squawk. several seconds after that he is reprimanded by approach and told to enter the "correct" squawk. The corrected squawk was the same number approach had given me. I called it in and it was a non-issue and corrected immediately. But it helped me remember people make mistakes and that could have resulted in some serious in air confusion.
Lesson: Always pay attention, you are always the final authority on your own safety.
Second: Over the past week or so, I began to notice my aircraft was starting to take a little more oil than it normally did. The amount wasn't alarming since it was well inside normal usage, but rather the change is what started to concern me. I couldn't see anything else wrong so I continued flying, but kept an eye on things. A few days later I noticed that my oil temperature gauge was running hotter than normal. It was still well in the green, but it was noticeably warmer. I thought maybe the fairly warm air may have been the culprit, but I ran the engine a little cooler in case. Then the engine started running a little rough, and that was enough for me, I brought the plane back in. After I landed I noticed oil dripping from under the cowling, turns out I had a leaking oil filter. The roughness turned out to just be a plug that was fouling but it helped me make my decision. I always had a rule of 1 Big Concern or 3 Smaller Concerns that would determine when I would not continue my flight. I hit my limit, so I came down and I am glad I did.
Lesson : Always have your personal limits and stick to them
I'm always learning, and it's thing like this that make me glad I am.
