Xcaliber
El Chupacabra
I feel that as a CFII and ATP I really should know how this stuff works by now.
So I was thinking upon altimetery today. We're given an altimeter setting on the ground, which presumably is only corrected for non-standard pressure. We set in that and low and behold, we see the airport elevation, within a margin of error for the system. On my aircraft, that margin is 75' if I'll be flying in RVSM. That's all hunky-dory on a standard day. But we also know that on a non-standard day, especially cold days, we have to watch out for our true altitude being different than indicated. Based on some quick E6-B action, I figure that (depending on airport elevation), any time the temperature is more than about 4 or 5 degrees C from standard, I'd be outside of my aircraft limits. Ie, my indicated altitude would be more than 75' off from field elevation.
Now obviously that doesn't happen. If I set in the given altimeter setting, it's usually well within limits. So that means either one of two things...either temperature doesn't have as big of an effect on true altitude as I thought, or, more likely, I've been taught (and teaching...) wrong all these years and altimeter settings DO in fact take in to account non-standard temperatures. Does anyone have any sources on how altimeter settings are generated? Are there some older systems out there that might not take temperature into account?
On a somewhat related note, do aircraft with Air Data Computers automatically correct for non-standard temperatures? I've never read anything about any systems that do, but you would think that it'd be feasible to do it.
