Can anyone explain this:
As alt increases outside pressure falls. So if pressure at sea level is 30.02, then at 100 feet the pressure should be less than that, something like 30.00. Since the pressure falls 1 inch for every thousand feet, then at 1000 feet it should be approximately 29.02.
However, to compute pressure altitude the conversion table tells to do exactly the opposite. The pressure altitude (which is the altitude where pressure is equal to 29.92) in the above example will be equal -75 feet, which is exactly the opposite of what logically should be happening.
Where I am wrong? Thanks.
