The pilots had used a laptop computer to calculate how far the plane needed to go to land, the NTSB said. When the runway's condition was entered as "wet-poor," the computer calculated they would be able to stop with 30 feet to spare.
But the calculations took into consideration that engine thrust reversers would be deployed at touchdown. Instead, the NTSB said, "flight data recorder information revealed that the thrust reversers were not deployed until 18 seconds after touchdown, at which point there was only about 1,000 feet of usable runway remaining."
Without the thrust reversers, the calculation would have shown a safe landing was not possible, it said.
(emphasis added)The Federal Aviation Administration (FAA) does not allow the use of the reverse thrust credit when determining dispatch landing distances. Further, the decrease in stopping distance resulting from thrust reverser use (which increases the safety margin) had typically been used to offset other variables that could significantly degrade stopping performance. However, the FAA allows the reverse thrust credit to be used in calculating en route operational landing distances for some transport-category airplanes, such as the accident airplane, a 737-700. Accordingly, when using the reverse thrust credit for contaminated runways, the required runway length for 737-700 model airplanes is about 1,000 feet less than the required runway length without the reverse thrust credit. The OPCs of Southwest Airlines’ 737-300 and -500 model airplanes do not use the reverse thrust credit; therefore, these model airplanes have a greater landing safety margin. In this accident, when the thrust reversers were not (or could not be) used in a timely manner, the airplane could not be stopped on the runway because of the absence of this extra safety margin.
Doug Taylor said:When, in the history of professional aviation, has anyone seen a landing performance chart with a calculation for thrust reversers?
Doug Taylor said:Indian-style even.
Doug Taylor said:My paternal grandmother is Blackfoot!
Doug Taylor said:Is it that you hate the webmaster or that you just hate America?![]()
Try a Kingairism, then. They're fun and refreshing!Doug Taylor said:You win. I'm out of Sean Hannity-isms!
Chris_Ford said:I, like TonyW, hate America. But for completely different reasons, of course![]()
