NewsBot
Administrator
Sierra Nevada Corporation Tallahassee, Florida:<BR />Are you looking for an opportunity to deepen your flight safety and schedule coordination skills in a meaningful work environment that supports and protects explorers and heroes? Join our team! <br><br>As an Aircraft Schedule and Dispatch Coordinator III, youll be responsible for the coordination of safe and efficient operations in a narrow range of areas affecting flight safety in accordance with federal aviation regulations and company flight manuals. Youll preplan daily flight operations, inform appropriate station staff concerning changes in flight status or schedule, and ensure crew and aircraft are available for each scheduled departure. Youll also track, coordinate and schedule all required aircraft and aircraft component inspections and scheduled maintenance<p></p><p></p><p>The ISR (Intelligence, Surveillance & Reconnaissance), Aviation, and Security (IAS) business area is a leader in ISR and aviation, it is a leading prime manned and unmanned aircraft systems integrator for innovative, high-performance ISR and aviation systems. Its end-to-end Command, Control, Computers, Communications and Intelligence, Surveillance & Reconnaissance (C4ISR) capabilities encompass design, integration, test, certification, ground/flight training and complete logistics support. IAS tailors solutions to customer cost, performance, and schedule requirements and designs to consistently exceed expectations – with an unrivaled record of on time and on (or under) budget deliveries. Learn more about IAS</p><p></p><p>
Continue reading...
Continue reading...
