Looking4Lower: Does this reply also help with your question about whether you can use a generic manual if there is no official AFM?
From what I understand, POHs from aircraft built prior to 1978 do not have to be onboard the aircraft. Only on aircraft built after 1978 does the AFM have to be onboard.
I think!
[/ QUOTE ]A lot of people join you in your thinking, but it's not really correct. The change in 1978 was that, for the first time, a manual became a required piece of equipment for =all= aircraft.
Before that, you will find plenty airplanes in which a manual was a required piece of equipment. And, under 91.213, all required equipment needs to be on board.
In addition, whether one was required or not, if the airplane has a manual, it has to be on board (unless there are placards, etc that cover all of the information)
Take a look at 91.9:
91.9
(b) No person may operate a U.S.-registered civil aircraft -
(1) For which an Airplane or Rotorcraft Flight Manual is required by § 21.5 of this chapter unless there is available in the aircraft a current, approved Airplane or Rotorcraft Flight Manual or the manual provided for in § 121.141(b); and
(2) For which an Airplane or Rotorcraft Flight Manual is not required by § 21.5 of this chapter, unless there is available in the aircraft a current approved Airplane or Rotorcraft Flight Manual, approved manual material, markings, and placards, or any combination thereof.
(21.5 is the reg that has the 1978 date)
If the airplane is required to have one, it has to be there. If the airplane isn't required to have one, it (or a combination of information that does the same thing) has to be there
