MIKE....below is a list of AD's on the FAA website that CHARLIE posted. I've found some AD's not to be up to date on the FAA website, but if you know someone who works at a shop involved with General Aviation, they'd be in a good position to help you research through their AD resources to ensure there aren't any newer ones out there.
97-01-01 R1 12/08/1998 Main Gear Sidebrace Stud
96-10-03 06/14/1996 Flap Handle Attach Bolt
95-26-13 02/05/1996 Inspect Oil Cooler Hoses
94-14-14 08/19/1994 Nose Landing Gear Modification
86-17-01 08/21/1986 Ammeter Replacement
82-06-11 R1 06/16/1982 Nose Landing Gear, Inspect, Rig, Modify
81-11-02 R1 10/02/1981 Oil Drain Valves
80-19-01 09/12/1980 Carbon Monoxide In Cabin
77-23-03 11/14/1977 Rod End Bearings
77-01-01 01/07/1977 Fuel Quantity Gauge
76-15-08 09/24/1976 Nose Gear Trunnion
75-24-02 11/21/1975 Loose Seats
75-08-03 04/04/1975 Fuel Drain Valves
74-09-04 04/24/1974 Rear Seat Belt Installation
72-17-05 08/15/1972 Electric Trim Switch
72-14-07 07/07/1972 Bolts in Stabilator Hinge Fittings
71-21-08 10/13/1971 Binding of Fuel Selector Handle
70-26-04 06/24/1971 Stabilizer Balance Weight Tube
70-09-02 01/20/1972 Propeller Spinner
69-15-01 07/21/1969 Control Wheel Retaining Pin
69-12-01 06/10/1969 Air Induction Hose
