You can be an avionics technician without any license.
An FAA airframe license is desired if the operation requires you to sign off an airplane to airworthiness.
Other operations require a GROL (FCC General Radiotelephone Operator License) ((also lookup RADAR endorsement))
There are other non-government licenses and certificates out there that hold a certain amount of pull to certain companies but are not universally accepted.
Experience is a larger factor than licenses here. Working with wires, troubleshooting, wiring harnesses, troubleshooting, installs, troubleshooting, wiring diagrams, and troubleshooting.
I acquired my licenses through self study. Went for the Amateur Radio License then the GROL later on. Some schools teach it, may or may not be worth it.
A+P helps a LOT and makes you more versatile.
CE
30 years ago you could work as an avionics tech with a GROL. Now most airlines want both the GROL and the A&P. However 145 Repair Stations still hire avionics with (and sometimes without) a GROL. You can still get your A&P if you can come up with 36 month's of documented experience and a letter from your supervisor. So, the short answer is work for a 145 Repair Station for 36 months, get your boss to sign a letter and take that to the FSDO. Then it's up to the inspector as to whether or not he feels comfortable allowing you to challenge the tests (take your written, oral and practical) and get your A&P. Another way to do it is working for Boeing. But the local FSDO in Seattle refused Boeing workers. They are coming around. The issue with they had with Boeing is the workers were lacking any knowledge outside of their specific job. In other words you might only seal fuel tanks and have no clue about anything else. The inspector is gonna wanna see systems knowledge. You will have to work your way up to getting that kind of experience there.Can one solely be an avionics technician without having to get the A&P certificate?
Any resources to get started towards this certification?
Sent from my Nexus 7 using Tapatalk
