1.) If Flying a VOR/DME approach without a DME on board, can you use GPS in lieu of DME info(if the procedure is in the database)? Would this be an issue because DME is slant range, and GPS is ATD, so the fixes might be slightly different?
2.) When on a Victor airway, can you use the GPS OBS mode to dial the course(radial) of the airway and track to the VOR waypoint on the GPS, instead of the VOR?
3.) On the oubound leg of a DME fix hold, when do you start timing outbound? When do you turn inbound? I would think it would be abeam the fixes but your not measuring along the holding course when outbound.
