Back in my engineering days I used to work for mama Boeing and did lots of the airport compatibility analysis for the 777X. The -9 already presented several length related issues, mainly turn capability due to the long wheelbase, and tail overhanging many of the parking stands requiring mitigation measures on the aft service roads. Plus it technically requires ARFF category 10 firefighting capabilities (same as A380) by 1.5m, even though that exceedance was mainly due to the sweep of the horizontal stabilizer and we could often get it waived back down to 9 if you were a good talker. Stretching it even further would exasperate these issues and make it even more restrictive. It does you no good if you have an airplane that can only operate in a small number of airports, like the A380 was. Plus you have the issue of weight. With the gear configuration the 777-9 has the highest ACN of any other aircraft and this would sometimes be an issue. Unless they keep the same MTOW with the stretch, it's going to be even worse, and again, more restrictive. I think the market has clearly spoken that very large aircraft are not the solution going forward, outside of niche cases where slot restrictions are an issue, and the current order books reflect that. The 777-9 takes some regulatory legwork by my former colleagues but it can basically operate anywhere a 777-300ER can go. A potential -10 cannot say the same thing. I don't see it happening. In my opinion, and it is my personal opinion only, Boeing should focus on the NMA and a clean sheet 737 design rather than stretching this thing even further. We already saw with the MAX what happens when you keep stretching things way past their design point, and the funky landing gear design on the 737-10MAX is when I think they jumped the shark.
