not doing zany ####
I was asked that on my 112 checkride a few weeks ago. I remembered it this way....
FLAPS CHECK (√ )
Flight Path (Correct)
Landing Configuration (Correct)
Airspeed (Proper)
Power Set (Appropriate for Aircraft Configuration)
Sink Rate (Not abnormal)
√ Checklists complete.
Hope that helps.
FLAPS CHECK (√ )
Airspeed (Proper)
Hope that helps.
I believe we were told that (1) elements describing a stabilized approach, (2) determining crosswind components, and (3) discussing personal weather minimums are supposed to be on every check from 102 through MEI...
6 elements? WTFO?
On speed
Configed
Sink < 1000 below 1000 AGL
Nuff said.
Configed takes care of all checklists, no need to reinvent the wheel here.
yeah i tend to agree. its kindof restating the OBVIOUS.
duh, im on an approach, OBVIOUSLY im monitoring and staying on the prescribed course.
stuff like that bugs me. if it slips your mind that you need to be following a course while on an approach, you have no business flying approaches.
perfect thanks.
yeah i heard this is some new thing theyre supposed to ask on all stage checks now.........but a lot of us were obviously not briefed on this.....
ok well, if your airspeed is appropriate, and your sink rate is appropriate, doesnt it NATURALLY FOLLOW that your power has already been set correctly???
