Dan208B
Anyone on here own an airplane with an O-320 or have lots of experience flying them recently? I have probably 500+ hours in 172s and Cardinals but it's been 5+ years since I've done it a lot. Purchased a Piper Pacer a year ago with a 160hp O-320 conversion. I just installed an EGT gauge and I'm looking for a few pieces of information.
-Is there a recommended max EGT for the O-320?
-What about optimal? I'd like to operate rich of peak. I've been not leaning below 3000ft, but on longer trips I'd like to start using EGT to lean. My carb is set up so ground leaning and leaning below 3000 isn't necessary and it never loads up.
-As far as this goes, what power setting to use with it, I typically cruise at 2300rpm which seems to give a good speed vs. fuel burn.
-Cold weather ops and startup - I preheat with an space heater ducted into the cowling and a blanket to keep in the heat. Upon startup, should the engine be idled at 700ish RPM for a couple minutes or 1000 right away? There seems to be different thoughts on this.
Thanks for any info anyone can provide!
