I'm not the Doc, but after the FedEx accident the NTSB recommended that all the current color screening methods (including the FALANT) be evaluated and possibly removed as an alternate test. Here is the correspondence between the FAA and NTSB regarding the NTSB's recommendation. The bottom line is that the FAA is still researching the issue.
From the NTSB website:
Safety Recommendation History for A-04-047 FAA
Response Date:
9/13/2004 From:
Addressee Response:
Letter Mail Controlled 9/22/2004 9:38:22 AM MC# 2040571 The Federal Aviation Administration (FAA) has reviewed the Federal Express accident and the two other accidents in the Board's database where pilots with valid medical qualifications were involved in accidents where deficient color vision was cited as a contributing cause. On August 5, 1980, a Navy F-4J was lost when a severely color deficient pilot failed to interpret correctly the colored navigation lights of other aircraft in the area, leading to the false impression of an impending collision. On August 29, 1992, the pilot of a Mooney 20F, with a "waiver for partial color-blindness to red and green," was startled by a near miss, and decided to land on the first runway he had in sight. The runway he chose was marked ''closed'' with orange crosses on the soil 50 feet beyond each end. The pilot stated that he had checked the NOTAMs and was aware that the N-S runway was closed. The Board listed his limited ability to detect the orange closed marking as a factor. The FAA recognizes that color vision testing methods and the relevance of color vision deficiencies to aviation safety are controversial, both in the United States and worldwide. The FAA is also aware that efforts are underway in some countries to assess color vision testing methods for airmen and possibly develop a color vision test that may be more appropriate than those presently in use. The FAA accepts several color vision screening tests for airmen and employs practical testing with signal lights to determine whether an airman should be permitted to perform aviation duties without limitations. While the FAA does not believe the above mentioned accidents provide compelling evidence that the current color vision discrimination tests are deficient, because a number of these tests were validated years ago and the demands for color vision perception in aviation are changing, the FAA believes it is appropriate to conduct the research recommended by the Board. The FAA anticipates that the research necessary to identify, develop, and validate a new color vision screen that is in compliance with existing Federal regulations will be a substantial effort. Careful consideration will be given to the added risk associated with any performance differences between pilots with normal color vision and those with varying degrees of color vision deficiency. In pursuing this research, FAA must consider other safety research priorities and the availability of resources. The following is a tentative schedule for pursuing the research initiative: · Conduct an extensive review of the literature related to color vision and performance on color-coded displays, with particular attention to the flight environment. (Estimated time for completion is 6 months.) · Establish a group of subject matter experts from the aviation community to review existing and emerging aviation displays and the flight environment to identify systematically the use of color, to identify instances where color is used as a non-redundant cue, and determine whether pilots who have a color vision deficiency may respond in a manner that may compromise safety. (Estimated time for completion is 1 year.) · Use results of the review and analysis to develop a research study that assesses the ability of color vision deficient individuals to respond to information from cockpit displays and the aviation environment, as well as respond to simulated red-white VASI/PAPI lights under time constricted conditions. (Estimated time for completion is 2.5 years.) · These results, along with those of research currently ongoing in other countries, will provide the necessary information regarding the modification of existing standards and the development of a revised testing protocol, including practical tests. (Estimated time for completion is 2.5 years) I will keep the Board informed of the FAA's progress on these safety recommendations.
Response Date:
1/12/2005 From:
NTSB Response:
Pending the results of the FAA's color vision testing research program and appropriate revisions to the color vision testing protocols used for recurrent medical examinations and certifications, Safety Recommendations A-04-46 and -47 are classified "Open--Acceptable Response."
