You'll hear all sorts of horror stories about ice, and the van. The caravan dosen't handle ice any better or worse than any other turboprop.
I'll disagree with this. Unless, you mean "...other single engine turboprop".
I've flown King Airs and they'll handle a the ice a LOT better than the caravan. The van just isn't fast enough to deal with ice using boots. You need the speed...and at 150-160 knots, the boots are losing effective ness especially on those big wings.
Now, the nice thing is...it's a PT6 and it'll take you as high as you want to go (up to FL200 in ice) if you can keep it above 120.
When I'm flying the van, I don't fly it over large bodies of water (great lakes) and always have an out in case of engine failure or ice. It's a single engine airplane and I treat it as such.
Having said all of that.............it's a 182 with a PT6 up front. I'll second the recommendation of taxing in beta and being cautious of using reverse on the runway. I usually just put it in beta once I'm on the ground...the brakes are good enough that if you don't slam on 'em you aren't going to blow a tire or lock one up.
The systems are pretty simple. It seems like everything is electric or run on bleed air.
We run ours at max tq, 700 ITT or max NG......whichever comes first. I've seen about 165-170 TAS on average which is 150-160 IAS at 5-9k.
It's a fun airplane when it's day VFR, but that's because I'm very uncomfortable with single engine IFR operations. I really don't like it. YMMV.
It's easy, you'll have no problems. Good luck.
-mini
