killbilly
Okay, I've run into this question 2X on two different tests, and I keep getting the answer wrong, which means a) I'm doing it incorrectly or b) the answer to the question is wrong.
So I'm posting the question, and I want to see what you guys come up with. If you could tell me how you come up with the answer, I would appreciate it, because I'm apparently lacking something in my studies and feeling silly. Thanks in advance.
"On a cross-country flight, point A is crossed at 1500 hrs and the plan is to reach point B at 1530 hours. Use the following information to determine the indicated airspeed required to reach point B on schedule:"
Distance between A and B: 70NM
Forecast Wind : 310 at 15
Pressure Alt: 8,000 ft
Ambient Temp: -10C
True Course: 270
The approximate required indicated airspeed would be: ???"
I believe I've been getting it wrong because I'm running the wrong calcs on the E6B.
The way I'm reading it, I need to go 70NM in 30 minutes, which means a GS of 140kts. From there, I take the GS and correct for wind and pressure/temp, right?
Help!
Ambient Temp: -10C
True Course: 270
Help!
