mhcasey
Once again, the FAA books have let me down and I come seeking a more thorough understanding.
My thinking: In a skid, the inside wing stalls first because it's aoa is greater than the outside wing. I'm having a tough time visualizing this, though. I can see two possibilities:
1) The outside wing literally receives more air over its surface than the inside wing due to interference from the fuselage. Also, relative wind will tend to move inboard over the outside wing, but outward over the inside wing, so the inside wing will produce more induced drag as more air will escape off the edge into a vortex (though the interference drag at the fuselage on the outside wing may counteract this?).
2) The inside wing is "slower' into the wind than the outside wing, though this only seems to be the case if there is some acceleration around the vertical axis.
I know the inside wing would stall first, but I'm not convinced my explanation is thorough or even completely accurate.
Also, why the incipient and recovery phases? Does the plane's inertia just initially want to remove it from the spin until all of the forces balance?
Thanks in advance, and I look forward to hearing another crystal clear and useful explanation.
