amorris311
pyro's all of you! then again i used to burn a lot of things when i was younger.:
OOOhhhh.....ya'll are talking about when ya'll were YOUNGER. Never mind.pyro's all of you! then again i used to burn a lot of things when i was younger.:![]()
My eight year old boy is already showing signs. Everytime I light the charcoal BBQ he wants to be the one who throws the match on.
Oh when I was in the Arabian Sea we took the MRE heaters and turned them into bombs and threw them off the ship. Marines showed me that trick on my first deployment. Ships captain was not happy!
Want real fun, play with solid sodium....outdated is even better.
just add water, exactly what it says to NOT do on the label.
2.5 pounds in a pool does some interesting things!
we took the MRE heaters and turned them into bombs and threw them off the ship. :nana2:
Now, has anyone ever used an old Kenmore vacuum and a Holey electric fuel pump to make a homemade flamethrower to avoid shoveling snow??
Okay. How do you do it? This I want to know.
Actually the old homemade flamer was not the hardest (or most destructive) of my childhood creations.
As I recall, and I am digging way back as this was over 20 years ago, the design was simple enough.
My idea was, blowing air (Vacuum), introduce fuel (Fuel pump and gas) = flamethrower. Well, it didn’t work out quite that simple in the end.
First, I started with an old vacuum that we were done with (we had a brand spanking new Kenmore). The vacuum had a blow feature, well actually it was a matter of an outlet hole that the hose fit into rather then a reversible motor or anything like that. Either way I had a vacuum hose, and the long metal extender pipes, blowing forced air.
Second step was introducing a spray of fuel into the stream of air. This turned out to be the toughest part, as it seemed everything I did didn’t work right the first time around. Sparing you the explanations of every revision required, in the end I had a hose coming from the pump plumped into a bit of the rubber vacuum hose. The end of the fuel pump hose had a small nozzle that turned the fuel into a mist (a bit like a fuel injector). I also had to use a tee fitting on the hose with a return to the fuel tank, as the fuel pump put out 8 psi and something like 45-50 gph, which was far more then what was getting through the nozzle, and without the return line the pump would overheat.
The last part was ignition, which was a problem with a simple solution. After starting the vacuum, now with a mist of gas mixed with the air, I first tried to ignite the mixture with a regular cigarette lighter (After taking a deep breath!). This worked, but the flame was blown out by the oncoming air, rather then the burning being sustained. The solution? One of those $8.00 butane torches you get from Radio Shack for soldering. I found a means to affix that to the end of the metal pipe bit of the vacuum hose, lit it up (it wasn’t blown out by the air flow), starting the fuel flow (which now I had rigged to a push button on/off switch to control the fuel pump), and
WHAM!!!!![]()
Now don’t get me wrong, this didn’t exactly rival Apocalypse Now or anything, but it did melt snow! It also seemed to have a high entertainment factor!
Oddly enough, despite my offers, none of my neighbors wanted me to remove their snow.
Wonder why?![]()
