4−4−6. Pilot Responsibility upon Clearance
Issuance
a. Record ATC clearance.
.. omitted for brevity ...
b. ATC Clearance/Instruction Readback.
Pilots of airborne aircraft should read back
those parts of ATC clearances and instructions
containing altitude assignments or vectors as a means
of mutual verification. The readback of the
“numbers” serves as a double check between pilots
and controllers and reduces the kinds of
communications errors that occur when a number is
either “misheard” or is incorrect.
1. Include the aircraft identification in all
readbacks and acknowledgments. This aids controllers
in determining that the correct aircraft received
the clearance or instruction. The requirement to
include aircraft identification in all readbacks and
acknowledgements becomes more important as
frequency congestion increases and when aircraft
with similar call signs are on the same frequency.
EXAMPLE−
“Climbing to Flight Level three three zero, United Twelve”
or “November Five Charlie Tango, roger, cleared to land.”
2. Read back altitudes, altitude restrictions, and
vectors in the same sequence as they are given in the
3. Altitudes contained in charted procedures,
such as DPs, instrument approaches, etc., should not
be read back unless they are specifically stated by the
controller.
c. It is the responsibility of the pilot to accept or
refuse the clearance issued.
