good luck. in my experience it takes two maybe three annuals to figure out all the head scratchers/shoddy repairs from its previous life, may they be insignificant and inexpensive![]()
People knock flight school planes, but when this one was such a plane, it did appear to get very thorough MX according to the logs. It mostly sat for two years after that, and got pencil whipped annuals, so that's mostly what I'm dealing with now. Fingers crossed that it's just neglect items.
If your shop is amenable to it I highly recommend that you participate
See if you can. My old shop used to let me do as much as I wanted under the supervision of the mechanic and I learned a ton. Some shops do that some don’t, but I would take every opportunity to learn your machine with a wrench in your hand.My work and travel schedule will make that tough, but possibly once I see the list of recommended repairs.
Wrong deities apparently - it was no bueno. About $12K in airworthy repairs. To be fair, a third of that is repair to a crack in the seat pan, which my A&P found when he initially poked around the plane. Recommended repairs would add another $11K if I did them all.
Surprised, but not shocked. The plane sat for two years outside, and the purchase price was about $10K less than other comparably equipped planes (largely due to the first airframe log covering through 1991 missing). Am pissed what the pre-buy mechanic has cost me in all the things he missed, though. Lesson learned. My guy found loose bolts and even some blue work towels just hanging out in the wing, which is scary AF.
Going to try to get this down to about $15K. The cables all have signs of corrosion, so he quoted me recommended rates for replacements, but they may be able to be cleaned and salvaged - TBD. That would help for sure. Other corrosion was manageable and spar looked good.
I sympathize. “New to you” aircraft cost at least 10% of the purchase price in “fix it items” after purchase, but it has a hard floor of about $10k regardless of price.
I think I was into my Bonanza for about $20k post purchase to fix up all, including the nice-to-fix items, getting the AC going, and a complete going through of the gear system.
I’ve found that I’m the one that needs the flashlight and crawl around in the airframe for any pre-purchase. Care for an airframe leaves tell tale signs that tells you if something has been looked after. If they ignore one area, it’s probably more than just that. A&Ps look at the micro, I look at the macro.
Yeah, it's a bummer, but I at least console myself in the fact that I do believe I'll be able to recoup a portion of the investment, as I bought the plane on the cheap.
Have an idea I'm going to discuss with the A&P tomorrow. There are a few "airworthy" items that aren't passable for an annual, but aren't a legitimate risk to safety right now - namely the crack in the seat pan on the co-pilot side, which is about $4,200. The aircraft isn't legally due for annual until May 2026. I only did this annual early because there were enough unknowns that I wanted my A&P to take it apart.
Going to talk to him tomorrow about him not signing off on the annual, and instead scheduling one for May ... then having him do the $10-$12K in work that I believe really needs to be done to make me feel comfortable flying it now, and the remaining airworthy items in May.
Just the knob or the whole dimmer? I’d have found a buddy with a 3d printer and owner produced part-ed that •Murdoughnut Jr. and I at Air Salvage of Dallas picking up a panel dimmer knob I couldn't find anywhere else for less than $200 for $50!
Just the knob - it’s actually two parts with a tiny hex screw, but I had thought about that option too.Just the knob or the whole dimmer? I’d have found a buddy with a 3d printer and owner produced part-ed that •
Doesn’t this kind of talk cause someone in L’Enfant Plaza to spontaneously crap their pants? (I have no idea.)Just the knob or the whole dimmer? I’d have found a buddy with a 3d printer and owner produced part-ed that •
