AA OOPS
A1TAPE
I thought they had fixed the tail number/fleet issues after the Hawaii incident where AA sent a NON ETOPS plane there as revenue then had to tell the FAA about the mistake and ferry it back to mainland. Sounds like the swiss cheese model bored through almost all the way - the fact they landed in FCO stopped the cheese from being fully bored through.
On the new flightkeys system can your admins lock out aircraft from routes so they CANT be put on certain legs?
I checked and nothing in the NOTAMS prohibiting a certain aircraft type from landing there.
Shocked the airport didnt put anything in the NOTAMS saying no 7879 allowed.
From Jonx
ACFT 789 NOT AUTHORIZED AS PER AIRPORT AUTHORITY
Bet its buried in the AIP somewhere. Honestly I could see some crews calling the airports bluff and telling the airport authority and ATC over the radio ‘okay prove it. Prove we cant land here and NOTAM IT!!!’
Continued
Prove we cant land here and NOTAM IT!!! If its a ground handling issue (convenience) and NOT a safety issue (killer NOTAMS -ILS US or RWY closed, etc) then we are proceeding inbound’. iImagine if they didnt have the fuel to divert and had to land at Naples, the airport would have figured out a way to handle it.
US airports figure out how to handle situations all the time. Such as the APU fails at an airport which doesnt have ground equipment or it broke down, airport/airline finds or borrows a way to fix the problem (gpu/air start).
This example is a reason management continues to misunderstand flight keys. It will not prevent dispatchers from doing stupid things, save the company money, lower required the number of required dispatchers or replace us entirely. It will sometimes correctly apply notams, but it is not fool proof.
It's a system that makes good dispatchers better and lazy dispatchers worse.
In this case thought NO NOTAM was ever issued. Which is the airports responsibility. If u don’t want a certain aircraft type at ur airport NOTAM it or put it in the AIP.
Naples looks like PITA; one runway with five surface movement hot spots, 3.33° or 3.5° ILS-es, non-standard departure climb gradients.
And P.O.S. enav.it. I went looking for information about Naples on the ICAO-mandatory-available AIP and those •heels want to force you to sign-up for an account to access the AIP. And the dumb sign-up page is in baloney-speak only.
I could see AA sending a bill to NAP airport authorities seeking reimbursement for the diversion costs, hotels, pax vouchers, fuel, etc. Either the airport would ignore the bill, pay the bill, or have to prove/publish a restriction on 789s. Hopefully they would break out the AIP and AA can see for themselves if its published in there.
They won't. I have seen stuff like this at many airports. No NOTAM will be issued for these issues (only time would be for a wingspan restriction on runways the sizes we use at the larger carriers). I have seen places like CPR where a 752 can use for adequate airport usage but the 753 cannot unless an emergency is declared. It boils down to runway and airport certification for the size/weight and the airline getting them added to the Airport Authorized list. It is for the dispatchers and routers to verify that variant is allowed to go to these airports. Recently I had to call the routers when I got an "upgrade" for flights to DAB while they worked on the long runway, and had to call the routers to get one of the authorized on the 10-7A TMP to be allowed to go. If the SOC/NOC/OCC employees don't check it, enroute ATC would have no way to know or reason to stop the flights from going that far.
If the 789 has never been authorized and it's in the airport documents, why make a NOTAM for it? If it's PCN or something like that, that's for the dispatcher and crew to look into. The thought of creating a NOTAM when the information is already available elsewhere is why airports in the US can have 100 NOTAMs but ones in Europe rarely have more than 5.
  • Like
Reactions: bp
apparently the brass at our company has quite a bit of buyers remorse on flightkeys. It has a decent interface for building flights/doing reroutes/ diversions, but it isnt capable of saving any money. The optimized routes? Dc center hates them and we have had to keep people on hand and spend several hours just programming in required routes. Not to mention the triple time paid for ot while people were in training.
Wow, you guys can make triple time? I’m jealous.
My guess…. It’s most likely due to parking stand availability. There’s only one parking stand that can handle the 787-9. It requires two other stands be empty to do it. The 787-8 can use a single stand without interfering with other parking,
<Sarcasm on> This all clearly spelled out in the Airport Reference information under Gate & Ramp operations, Something I check for every airport I send a plane to <Sarcasm off>
I need to get me some of that triple time training pay.
  • Like
Reactions: bp
I feel like they would just hard stand it at that point. Kinda like when Delta made Qatar hard stand an A380 in Atlanta.
If its an ARFF issue where they csnt support index E aircraft, then why publish NOTAMS pertaining to unsupported aircraft? If they had to downgrade service they should NOTAM it. Would love to look at their AIP to see the actual index for them.
A) LIRN B) 2503171804 C) 2506112359 ESTE) ACFT ICAO CODE 'E' LANDING ON RWY 24, SHALL VACATE RWY VIA TWY B.IF UNABLE TO COMPLY, ADVISE ROMA RADAR ON FIRST CONTACTON FREQ 124.350MHZ OR 134.200MHZ.REF AIP AD 2 LIRN 1-15/18
It was an AR
This was the real reason they had to divert
No, it wasn’t. Taxiways have not been evaluated to handle. 787-9. It was authorized and all good to go on paper. Dispatcher did nothing wrong in this scenario. It was the fault of several higher ups.
You should ask the international dispatch manager then. Or better yet send him an email. He loves those.
