I guess scrapping them must have been cheaper than dropping prices?
Reminds me of the starships. Well I was interested in one until I read how they were scrapping them. Instead I bought another 152 today. I was bummed to hear there was no interest.If they sell it they have to suppport it, less deliveries less time needed to support them.
The saddest part is they actually are a fun airplane to fly, it is the LSA standard that is the problem with it. Should have gotten them standard airworthiness certification and upped the MTOW
If you thought the 162 was fun to fly, obviously you never flew any of the other new, composite built, Rotax powered LSAs. I know this forum hates on the Rotax 912, but it's a great engine for that size airplane
Would've been a 150 replacement.
It's been a while since I looked at the stats but...Which has been sorely needed in the market.
If Cessna had built the skycatcher as a 152 replacement in the normal catergory with a 1750 lb MGTOW, they could have built it sturdy enough to last in the flight school environment as a primary trainer. But since they were working under the LSA weight cap, they had to shave ounces where ever they could, and wound up with a "cheap" 120K airplane that was constantly broken for simple stuff like door latches.
And eventually the stock of creampuff 152s will dry up, and the corrosion lurking in a lift strut attach point layup will cause a wing to separate, and an AD will come out, and $100k to rebuild a set of wings will kill the type.It's been a while since I looked at the stats but...
The skycatcher literally was a better 150, similar speed, similar payload, but wider cabin (same cabin width as the 206)
The price, the fact that it was built in China, and the weirdo control setup is what killed it I think.
You can still pick up mid time 152's for 30 to 40 grand for a cream puff and they don't have a bunch of A model things to deal with.
I may not have gone where I intended to go, but I think I've ended up where I needed to be.
- Douglas Adams
