You don't fly boeings or airbuses. You operate them. Airline pilots are more akin to systems operators than they are aviators.I guess I'm the only one that doesn't like the bus that much. It just doesn't feel like flying anymore and it was a step back in technology for me but it's easy and the paycheck and QOL are amazing so I can't complain.
Aviators today decide which system to operate...You don't fly boeings or airbuses. You operate them. Airline pilots are more akin to systems operators than they are aviators.
All these people bitching about the 737, realize half the forum flies the CRJ, or worse...
Meh.
I chuckle when AB pilots turn A/P off to try and make a descent.
"If Otto can't do it, you probably can't either."
If 180kt OP DES, Flap 2, and Brakes out won't make it, it was never meant to be...
Not an Airbus guy, but more than one conversation happened coming into SLC in the E75 to the effect of "if you don't turn the VNAV off and start getting the desired performance, we'll get to do a go-around in front of a bunch of new hires at The Hangar. And it won't be our fault, but we'll be the guys who look stupid because of SLC TRACON.""You just got Salt Laked, son!"
It wasn't really worth it at $43/hour.Go-arounds pay more!
;p
I wouldn't have guessed that to be true for Boeing. The Airbus doesn't require much sidestick input in gusty conditions since the computer does all the work. The high crosswind takeoffs are just awkward since ailerons aren't suppose to be used on the ground. Any other time just pick a bank and/or pitch and the computer auto-trims and holds it for you with the stick in neutral. I've never flown a boeing but I don't believe it does that. Hand flying isn't really hand flying any more in the bus but I haven't heard the same about Boeing?
Yall don't put aileron into the wind in a crosswind at your carrier??
Come on people, it's just an airplane. You know what an airplane should look like in any given situation, just do with the stick what you need in order to make it look right. High crosswind takeoffs are cross controlled until liftoff just like any other airplane...
The new Boeings (not 737... that's lipstick on a corpse) autotrim for you, just they keep the stupid yoke out of pride.
Aileron on takeoff is not recommended because the spoilers deploy. You have to use some aileron on a strong crosswind but it's just a different technique to learn to use less aileron and more rudder vs a regular jet. We service some airports with short runways and I wouldn't want to be killing my takoff performance with spoiler drag with large aileron inputs. If you don't care about reducing your takeoff performance then keep doing what you're doing.
Go to 3/4 of the cross deflection of the stick and you'll never pop a spoiler, plus have better crosswind performance. Try it next time you're taxiing out to see when the spoilers pop, and bring a nice plate of crow back here. It's yummy!
Trust me, I haven't stayed at a Holiday Inn Express in years.
Meh.
170 OP DES, gear down, Flaps 3 is your last resort and if that doesn't work, nothing will!
Speaking of that, as a former Boeing pilot, the idea of slowing down in order to go down was complete weirdness.
