Ground doesnt say go to Tower?
Wait till you go south of the border where ground doesnt exist except on the chart, tower is ground, and departure is tower.
On a related note, I can't stand when approach tells you to call the tower at the marker. Sets you up.
Seriously.
"We are cleared to land, right? It's all blending together."
(no, I'm not looking for the winds, just the magic words "cleared to land")
  • Like
Reactions: Cav
It is also a fun one when you get your take off clearance as well as full IFR routing while holding short of the runway.
Sent from my StarTac using Etch A Sketch.
Just play it safe and always transmit on guard
GEEEEAAAAAAAUUUURRRRDDDDDD
"I know, I'm trying to reach SouthernJets 2661."
"Was that 2751?"
"GUARD"
"No, SouthernJets two six six one. SouthernJets two six six one, Buzzsaw 4764 on guard. Please contact Minneapolis Center..."
BLOCKED
GUARD
With two radios there is no reason you can't have one on ground and one on tower as you approach the departure end. With only one radio I always switch when nearing the approach end (if #1) or stopping behind the stack (as log as all taxiway intersections are behind me).
I almost never call the tower to advise them I'm ready.
Unless you're using #2 for ops then switch it to 121.5.... Guess we need 3 radios.
Maybe CPDLC will fix this....
Unless you're using #2 for ops then switch it to 121.5.... ............
And what exactly would you be listening for on Guard while on the ground during taxi?
IF you seriously run your radios like this, then I recommend my single radio suggestion............
I'll hazard a guess you don't fly 121.
My company says "monitor guard on a secondary radio when not in use" in our FOM. Our FCOM specifies that we do this on the before takeoff checklist, which, while no specific minute-based time frame is given, generally states it is to be accomplished when the second engine is started.
Yeah, do you hear this @PeanuckleCRJ? :)
Old sim trick.
Most large airports tell you to contact tower at the marker, so most of the time (particularly with noobs), I assign them a speed to the marker and tower at the marker. Realism!
Guard on taxi out has saved a few of our guys' butts when they accidentally switched to the wrong frequency at busy airports. Yeah, it sucks on the east coast with all the children yelling at each other, but it's worth it.
My company says "monitor guard on a secondary radio when not in use" in our FOM. Our FCOM specifies that we do this on the before takeoff checklist, which, while no specific time frame is given, generally happens once engine 2 is started (2 to x minutes prior to takeoff based on engine warm up and checklist timing).
I put that in practice by as soon as I'm transmitting on radio 1, guard is on 2.
Other than the fact that no airline does it your way.
When do you guys generally switch to ops... I mean guard?
All I do is follow company policy *coughHATScough* so I'm going to just go ahead and say that if you have a beef with the way our company policy specifies radio use you can submit a suggestion. ;)
