Refusal to submit to DOT random urinalysis
Well, the MRO determined the test wasn't conducted up to spec so it got tossed and I'm back in the random pool and returned to duty.
Though I may see a professional and get the issue documented anyway.
Odd that the procedure calls for you to be observed providing the sample. I've been selected for random testing, and it wasn't observed, although the technician did wait outside the bathroom.
It wasn't observed, same as what you experienced.
The trick is to drink a big glass then wait 10-20 min. Than drink a second, it will trick the body into "making room".
For me it is psychological. Knowing someone is waiting for me just makes it clamp down. Can't explain why. Just happens, and not every time. Weird.
So the problem isn't so much one of refusing to submit as it one of being unable to perform. Seems like they are two very different issues. Bashful kidney or shy bladder is a pretty well known issue, and I'm certain the lab has encountered it many times before.
Actually the lab I went to hadn't. Or at least didn't claim to. I'm wondering if anyone has had this happen and had to go before an MRO?
This is very general...
The problem is that, at some point, inability can be treated as refusal. If you can't after a wait (if you refuse to wait, it's a refusal), the procedure is a medical referral to find out why. The doctor to who one is referred makes a determination whether there is some medical reason for the inability. No clear indication of a medical reason, there's a potential refusal issue. I haven't seen anything one way or the other, but I wonder what the FAA (as opposed to DOT) would do if there's a diagnosed psychological reason.
So, this is definitely something to discuss. With a personal physician, privately, not a lawyer online.
The NCAA urine test is far more intrusive then anything I've experienced with the DOT test. Not only do you have to stand in an awkward position you have someone look above and behind your scrotum.
Tomorrow I'm signing up for the AOPA legal/medical package. Hope to get this thing squared away, it looks like phobias are generally accepted by FAA medical as long as they aren't flying-related. Where's the good doc when you need him?
I would do that.
Also,so long as you are an AOPA member anyway, why not hop onto the AOPA forums, don't use a user name, and post anonymously in the Medical Matters section. Bruce Chien will give you a straight answer.
