... After passing the missed approach point the crew discussed a go-around and communicated with dispatch, then disengaged both autopilots engaged in the automatic approach and continued manually on flight director. Engines accelerated to 83% N1 (near Go-Around Thrust) and continued at that speed until almost impact. The aircraft began to pitch up under the influence of engine acceleration and flaps retraction reaching 25 degrees nose up, the stabilizer trim system wound - most likely automatically - nose down commanding the aircraft into a dive. In the meantime the crew retracted the gear, there had been no input on the yoke since deactivation of autopilot until that time, the airspeed had decayed from 150 to 125 KIAS. The crew now applied full forward pressure, the aircraft began to accelerate again after reaching a minimum speed of 117 KIAS at 700 meters/2300 feet above the runway, and began to rapidly descent, EGPWS alerts "SINK RATE" and "PULL UP" sounded, there was no reaction to the extreme nose down attitude however and the vertical acceleration became negative. The aircraft impacted ground at 75 degrees nose down at about 450 kph at coordinates N55.608818 E49.276852, the impact occurred 45 seconds after initiating the go-around and 20 seconds after reaching the maximum height...What happened in the 2013 crash?
