A-10's in the News - AF Keeping them a little longer.
It's not as if it's the only plane dropping bombs in close support of the ground force.
The writing on the wall of multi-role or no role has been there for 30 years. If an airplane as critical to a single role mission as Raptor had to pick up multi role strike when it's a mission only one plane (C model Eagle) was doing you aren't going to get to justify a 4.5 or God forbid 5th gen single role attack aircraft for CAS when you have 4 other planes in that weight class alone doing it. And more specifically in a med-high threat environment the A-10 isn't going to be able to do that role, it's going to be Strikes and 35s and Super Hornets that are viable and survivable. A-10 got its lunch eaten by SA-13... Put it on a battlefield with Gauntlet and Greyhound and no way are Hawgs gonna just roll in guns blazing.
Sure, the threat ring is there but I think there are areas where we shouldn't lap capabilities; this is one of them. Same goes for A/A. Let us build thoroughbred A/A and A/G platforms. If we designed and built single role/purpose platforms, I believe our procurement times-frames will drop significantly which will overall reduce cost of production/procurement.
Even now, generally speaking because that's all I can do here, while A-10s are operating in the Iraq/Syria area, they aren't operating everywhere. Depending on the assessed threat in different areas of that AO, determines which aircraft will be tasked into those areas. That said, Hogs don't go everywhere over there.
It's no surprise that the Hog is susceptible to various S/A threats. Even back in the Fulda Gap days with the Warsaw Pact, we knew that the 81st (and later also 10th) Tac Fighter Wing's 6 squadrons would be attrited in a couple of weeks or so, against the Pact's ADA forces. That isn't including jets which are taken out on the ground at the 6 German FOLs, or if things are going bad enough, at their home bases in Bentwaters/Woodbridge/Alconbury in the UK. The war would probably have gone tactical nuke by then, so it may not have mattered anyway, but we'll never know.
Desert Storm, we learned a big lesson when we brought the Hog with it's daytime low-level Europe employment tactics to a threatre with flat sand and no terrain features, pushing them up to medium altitude and forcing two squadrons to pick up a night mission (this was before the time of NVGs or any night capabilities for the A-10). In addition to the pushing of Hogs far forward of the lines in order to go hunt mobile Scud missile systems, to which they had to be pulled back from after being shot up and shot down. Losses to systems like SA-9/13 and 14/16.....fairly old systems, but deadly anyway.....were what got our Hogs there. In fact, apart from a Roland, no US aircraft have been lost to any modern SAM systems.....yet. Everything we've lost has been legacy systems, interestingly enough.
So there are places Hogs can and can't go, in terms of survivability. Of course, its doubtful we'd send a Hog into a highly contested environment anyway, and even so, many platforms play in the CAS game.....they just do it in slightly different ways. Depending on the effect desired by the ground commander, determines the apppropriate asset to send. Sometimes though, only certain assets are available.
I hate hearing the oft-repeated "troops will die if no Hogs are around!"; because for one, it implies that our US ground troops are either too inept or too incapable of doing anything regarding their job, unless an A-10 is overhead. And two, since A-10s can't be everywhere where CAS is needed, and there were times when they weren't even in theatre, troops were still involved in situations that required CAS, and the aircraft that responded got the job done, even if not possibly the most optimal platform. Again, Hogs can't be everywhere, doing everything.
The second stupid thing I get tired of hearing ad-nauseum, is the argument of "just give them to the Army or the USMC". For one, the Army doesn't want Hogs. Sure, they love the fire support they get from the jet, but the Army is happy as a clam to have the AF shoulder the cost of doing that, especially since that's the AFs designated job anyway following the Key West agreement. Too, the Army would rather spend $$$ on ground systems and doesn't have, nor want to spend money on (nor should have to) the infrastructure required to now have their own fixed-wing Air Force, and the huge financial burden that would be.
The USMC, the masters of CAS, while they appreciate the A-10, has no use for it as it has no shipboard capability. In addition, they're happy with what they have in inventory serving their CAS needs already. For a service that can take unlikely planes like the F-4 Phantom and F-8 Crusader, and make them effective CAS platforms, then these guys know what they're talking about in terms of what they need for themselves. And, they don't have any dying need for the A-10, although again, they appreciate that aircraft's capabilities.
Dude tell me again why you're flying helos and not a sr advisor/analyst?
The Gripen is a fine aircraft in its own right, but the idea of substituting them for the F-35 is an idea the armchair defense analysts proffered and has no realistic bearing.
I know a lot of Hog pilots, and not a single one ignores the surface-to-air threat. In my experience, Hog pilots are more skittish around certain SA threats (like the ZSU, or the Roland, or Crotale, etc) because they understand the limitations of their steed.
I have also flown a lot of CAS in combat, and I assure you that pilots in other platforms hold their support for ground troops as a sacred duty they are willing to give their life for.
I mispoke when i said ignored, i meant more of the lines of "seems more brazen" against the SA threat due to airframe survavability.
CAS in any support are always my favorite bunch of guys. I was lucky enough to sit with some Apache pilots after they covered us on a mission.
But i still love the A10 :). But whatever you fly Im greatful for any airsupport.
Can't ignore the SA threat necessarily, but I know what you are meaning. In areas where there's not a known threat system present, but there's the ever-present small arms/automatic weapons that I can't do anything about, I'll take it with some amount of a grain of salt if I happen to be going in low for a particular reason. But for known threat systems, the bad thing is that I can get shot down just like anyone else. I can take some punishment, but can be taken down with one round too if it hits in the right place. So known threats still have to be honored in that respect. We do have good ordnance and fuel endurance, but these days, the ordnance we drop is optimized for medium altitude anyway, just like everyone else. JDAMs, LGBs, Targeting Pods. Not like it was back in my day with dumb bombs and the only highest tech piece of ordnance being the AGM-65.
But the nice words are appreciated nonetheless. Just understand that we aren't invincible, as much as we'd like to be.
The thing is, there are many, many ways to "do" CAS. The A-10 does it in a few different ways, other platforms do it in their particular ways. Depending on the effects requested (and even the platform available at the time......Hogs can't be everywhere) as well as the threat present, will depend on what a particular airframe can do in a particular situation. Sometimes, A-10s will be optimal, sometimes not. Sometimes a different platform will be optimal, sometimes not. If you're looking for sorting a danger close of some small units in contact and the surface-air threat allows some permissiveness, then an A-10 is pretty optimal. If you're looking to destroy an enemy brigade massing outside a base camp preparing to attack, then a B-52/B-1 is optimal. Both situations are CAS, with the latter being closer to BAI, but still CAS these days. Point being that the A-10 is just a tool in the CAS toolbox. There are jobs that its the best tool for, and others it isn't.
There are times when an A-10 will indeed be decisive, there are times where it might not be. It all depends. The gun is a great weapon, but it too has both its pro's and con's insofar as usage.
The F-35, it's going to be simply doing CAS in its particular way, with its particular weapons systems. I'm very curious to see what TTPs the USMCs VMFA-121 and follow on VMAs that are transitioning to VMFA and the F-35, come up with. Being the masters of CAS, as well as the first service to go IOC with the F-35, what they come up with in that regard will be interesting to see.
Awesome info sir, I appreciate it.
Still love me that A10 in the way I love other Fire Support. Sure a mortar counts, but i think id still prefer a 155 ;)....you know the thought process of "when the enemy absolutely, positively has got to die".
Am I missing something or insane to think it would be a great idea that the Air Force acquire and use turboprop lighterweight COIN aircraft (Super Tucano, AT-6B, etc) for use when they've already established complete air supremacy and the risk of MANPAD/surface to air attack is low?
Am I missing something or insane to think it would be a great idea that the Air Force acquire and use turboprop lighterweight COIN aircraft (Super Tucano, AT-6B, etc) for use when they've already established complete air supremacy and the risk of MANPAD attack is low?
There has been a very vocal proponent of that very idea amongst all the service aviation elements for a while.
The reason it isn't happening is a combination of dollars diverted and lack of sustainable interest. When Tacanos and other similar light attack turbo props are costing 15-26 million a piece the argument of cheaper to acquire kinda losses a lot of its steam. Yes the day to day cost are arguably far cheaper than using thoroughbred race horses like Viper/Strike Eagle to pull the plow or on call CAS is definitely there but it's not like we are gonna get more money to buy one of these platforms. We are gonna have to find that 2-3 billion dollars by robbing it from our other platforms. And like it or not we are hopelessly falling behind on keeping our legacy fleets upgraded and alive. Stealing what little money we have allocated those programs isn't going to help that problem.
And while yes the cost of light strikes doing operations in a country is cheap it pales in comparison to the cost of say operating a no fly zone over a semi/non permissive environment like Syria/Libya with older less capable legacy aircraft. Let alone the cost in writing off a couple strike eagles or Vipers because instead of having 35 operational on day 1 to kick down the IADS door you sent them in instead since the money allocated to that is currently flying airplanes where there is no threat.
