LW bag question
B200 Hawk
I have had mine for coming up on 5 years, the steel frame is bowed on both sides. Has anyone ever attempted at remolding them back themselves? Or should I just go a whole new bag route. Don't feel like the hassle of shipping it off and spending half the cost of a new bag to refurb it...if that is still possible.
Thinking back to some engineering classes back in the day...
If it was my bag I would try to bend it back. Look at the metal, and if the deformation areas don't show any necking, tears, or wrinkles, then there hasn't been too much plastic deformation and you should be able to bend it back without damaging it much. If you do it slowly such that you don't generate heat in the bending zone, you should be able to avoid weakening the metal. I would try using two pairs of pliers close together to straighten out each bend, or a pair of pliers with the metal in a vise, clamped closely on one side of the bend. If you need to hammer it back into shape, do it by giving it a few whacks against an anvil or other rigid surface, let it cool, then a few more whacks. Hammering a metal will heat it up (you are cold working the metal) and too much heat can cause damage (crystal structure changes in the metal) that can weaken it or even fracture it if you get it too hot.
If the steel is of a type that is too springy and goes back to the bent state, then I would take it in for repair or replace it. Heat treating the steel (by fire would be easiest) without destroying the bag would be impossible, unless you can unscrew the metal parts to take them out.
This is ultimately why I decided against another LW bag.
$300 bag, at most 4-5 years of use, $60-$75/yr in depreciation...
I bought a TravelPro for $150. Going into year two with it now. Still looking pretty good, comes with a three year warranty even (includes shipping, I kept the box, my LW is now my backup bag I use when my wife takes my TravelPro on business trips...). That is at worst case $50/yr if it breaks on me at three years + one day. Oh, and it weighs almost half as much.
Refurbishing the LW bag costs around $230 and that's if they replace most everything excluding the handle and bottom casting. I've always liked refurb'd stuff but not a bag, mine was absolutely destroyed commuting. I sewed it back together more than once, welded the metal frame together after the screws stopped holding, etc. Just wasn't worth it. I'll just buy a new one every few years and write it off on my taxes.
I don't get why anyone uses LW bags. They don't hold as much, don't expand, they are heavy as hell, they are ugly as hell, and the whole replaceable model is great except it makes more sense just to buy a new bag.
You have to remember the design behind the bag. It wasn't really intended for people like you who have ample space to store your bag.
Considering the aircraft I fly right now I don't want my bag to be able to expand any further since it barely fits as is where I have to store the thing. The weight does suck but my bag has held up extremely well compared to previous plastic bags I have had.
because if you commute...any other normal bag will be destroyed within a year.....nothing holds up as well
I've seen my LW literally thrown from the jetbridge down to the ramp for a pink tag spot in the fwd compartment. Only scratched (call it character). These things are heavy (doesn't impact me) but take a beating. That's the difference. Sure, plenty of other bags would work under normal usage, but if you live through your bag and do a good bit of commuting, a tank is a good option. Never left me down. Other thing.. If you still have a flight case instead of efb the tank factor is even more important.
I remember a DL guy treating himself to a new LW bag when he got hired over there. He said he showed up for a trip and the CA looked at his pristine bag with a deer in the headlights look as if he was a brand new pilot. I think he said he planned on towing it around a parking lot behind his truck for "character" so he wouldn't scare anyone else. Thought that was a funny story.
Do any of you guys grind down the sharp edges, like on the feet of the bag? I've put some pretty deep gouges in rental car bumpers and I wonder if taking a file/angle grinder to it would help. I just don't want to do it and then have it start to rust.
Going on year 2 with my LW Stealth. I wouldn't have any other bag. It's taken a severe beating in a year of commuting and regional flying and held strong. I've seen a lot of other brands fall to pieces out on the line under similar daily abuse. Not my LW. And besides, if you realistically couldn't pack a week or two's worth of stuff in a LW Stealth (let alone enough for a 4 day trip) your doing it wrong.
Had my "Purtyneat" for 17 years now. Still rolling. Been back to the factory twice, once for a refurb, and once for a new main zipper. Been through 3 sets of wheels, 2 handles (first two were the old design, current handle going on 10 years) and innumerable zipper pulls.
Mine appears to be the 2nd generation, where the appearance is slightly better than the 1st gen bags, but they still seemed to be made from steel salvaged from German fleet that was scuttled at the Scapa Flow.
My only true complaint was I had to replace the kick panel after about 12 years, and the replacement part I got was so thin I burned through in about 9 months. I had to field mod the next one I got after that with some L channel. They replaced it for free when I got the main zipper fixed, and the new panel seems to be holding up without modding.
Point is, I got my money's worth out of this one, and it's still ticking. But your mileage may vary.
Richman
I need to send my big one back for a zipper. Puppy chewed a third of the main zipper off. I wonder if they would accept it with the puppy inside?
How much space do you need? I'm currently packed for over a week's worth of clothes plus a pair of shoes stuffed in the bottom and toiletries and other misc stuff in the front and side pockets. This bag fit in the old-style Brasilia overheads (just barely), the CRJ200 overhead, and scraped past the sharp aluminum corners of the CRJ200 cockpit closet many times.
I've had mine just over 3 years now and I've sent it back once because of zipper seem that started to separate. Overall I'm satisfied. I'll probably get another one when this thing dies, although it's certainly not showing any signs of giving up.
The crappy thing about week long tours is that I have to pack for 4 seasons almost year round. So I have my workout clothes and shoes, another pair of shoes, pants, shorts, jacket. Along with a weeks worth of shirts, socks, underwear, sundries, an extra uniform shirt, undershirts.
Try 17. Also underwear is for amateurs. See quote below.
