No not what I said. Sometimes SOPs are in contravention and I get paid to use my brain as a captain to make the big decisions.
Case in point. We are not required to do an auto land test unless the destination weather calls for Cat II/III because they have to be auto landed. Prior to departing, your destination is CAVU and no alternate is needed, with no alternate gas added. Upon arrival, your destination is Cat III, which can happen at JFK if there is a marine layer offshore. All airports in the NY area are down and your only real option is a Cat III, but you didn't do the test prior to departing so you can't legally conduct a cat III.
Now, your only option is hold and hope it clears to 1800 RVR. If it doesn't, you will have to auto land and as long as it works out, you're the hero. Screw it up, and it's carpet dance time.
This exact scenario happened to the LCA, that was why we were discussing it. One SOP, (no auto land test needed,) boxed them into a corner where the only way out was violating another SOP, (cannot auto land unless the test is performed first.)
